HACKER BRUSHLESS MOTORS
#496
I ran the 13.5 Hacker in the stock class at the Cactus Classis this year. I geared it 25/82 in a Losi xxxt-cr. It ran alright, I TQed 3 of the 4 rounds, was the only "stock" vehicle to run 15 laps & then blew out in 2 of the 3 A-mains to finish 2nd because I'm too nice. I'm pretty sure that was the gearing & it never ran hot. The outside temp was probably 90 degrees or so. Only got out motored once buy my cheating friend who posts on here as iamcornholio! J/K hope this helps!
#497
Does the 10.5 come with a standard amount of timing from new?
The endbell looks a lot like the Novaks with the periodical indentation on it. But when the Novak's are new these indentations are evenly spaced from the solder tabs etc. On the Hacker its already twisted around quite along way?
Skiddins
Skiddins
It woud appear that despite the position of the timing ring the motor had 30deg of timing as standard.
I have since been told that '0' timing from most manufactures is typically 30 deg.
This is 30deg;
Speed Passion
Hacker
#500
How about HACKER 13.5T fixed timing?
is it 0 fixed?
Thanx in advance
is it 0 fixed?
Thanx in advance
#501
Could somebody tell me how many KVs rating in the Hacker 10.5T?
In fact in english site, it says it has 3080KV, like that 1 of Losi which his derived from the same factory.
But in the german site, it said it really has 3500KV.
Then please somebody tell me which 1 is real.
In fact i want to have a sensored motor to race in 3100 class in my site.
Best regards
Best regards
#502
I am new to electric however not new to racing. I currently have a Novak 10.5 b/c almost everyone here at my club runs Novak, Why I have no idea.
When I came across this thread I began thinking are these just numbers or are the Hacker motors really faster?
Novak 10.5
Watts: 280+
Rpm:4000+
Hacker 10.5
Watts 400!
rpm 3000+
I'll be purchasing a NEW motor soon any info will be greatly appreciated
Novak 10.5
Watts: 280+
Rpm:4000+
Hacker 10.5
Watts 400!
rpm 3000+
has any one done a chart like this with the 17.5 motor on the market?
#503
Hello
I am looking at adding a 10.5 and a17.5 to my stable of motors.
I am currently running a MAMBA MAX PRO with LRP/Tekin and Speed Passion 2 10.5 and LRP and Speed Passion 2 17.5.
Looking at these 4 Motors combos
Hacker E40 - 10.5 -3500kv - 320 watts -25900 rpm
17.5 -2070kv - 210 watts - 15318rpm
Tekin 10.5 - 4500kv - 243 watts - 33300rpm
17.5 - 2500kv - 131 watts - 18500 rpm
LRP x12 10.5 - 3600kv - 306watts - 26640 rpm
17.5 - 2200kv - 183 watts - 16280rpm
Novak Balistic - 10.5 - 4200kv - 235watts - 31080rpm
17.5- 2200kv - 130watts - 16280rpm
Now in saying all of this the tracks that i run on are medium to large and technical to flowing So will the Hacker do the job.
Steven.
Steven.
#504
Anyone know what other rotors besodes the "hacker" brand I could use in my E40?
I know this is an old thread, but someone might know!
I bought the motor used, and I think the rotor is bent.
I've been racing with it, and it can still pull with the shiny new Tekins and Novaks, but it's just god-awful loud!
Even spinning it by hand it makes an aweful racket.
It doesn't help that I'm running 32P gears on my 2WD Slash either haha
But while I have money, I'd like to get a replacement rotor, I really like this motor!
And what's the diameter make a difference in? Speed?, torque? I have no idea.
I've tried installing the rotor from my Ballistic, but it's too long.
