Carbide Bits
Carbide Bits
About how many cuts can I expect from a carbide bit before it needs sharpening or replaced?
Registered User
It also depends on what type of material (how hard, etc) you're cutting, how fast you are cutting, rigidity of setup, etc.
Carbide usually lasts longer than HS, but is also more brittle. Great for hard material, but hates interrupted cuts.
Are you asking about a milling cutter, drill bit or lathe insert?
The guys on a Motor forum claim 20 cuts or so on a comm. I find that to be a little low. You can sharpen it with a diamond file (they are cheap). Just be sure to keep the angles the same and NOT round the corners.
A nice sharp bit will leave small pieces of copper all over. A dull one pushes the copper out of the way.
David Root
David Root
R/C Tech Elite Member
Carbide Bits
Guys;
Personally I have found about 20+ cuts before the bit needs sharpening/changing. The Copper used in Coms is very soft, but actually abrasive and hard on bits.
I am lucky enough to have a "Green" wheel for my Grinder, so re-sharpening is no problem. A "Diamond" file can be used also.
If you need new Bits, Try 'McMaster Carr' online. New bits are less than $5 apiece. There are several different sizes and styles availible, so order carefully.
Lots of info here, thanks guys.
Re: Carbide Bits
Originally posted by popsracer
Guys;
Guys;
whats the site for maccaster carr online ?
have anyone use the Xpress (the same brand that makes the car) lathe machine ??
What do you use to sharpen diamond bits?
Registered User
Silicone Carbide, I believe. And if I got it confused with the High Speed wheels; it's a green wheel... I think Aluminum Oxide is the normal wheel.
Registered User
You can buy a dimaond file for just a few bucks too. They work, just keep the angles the same
David Root
David Root
just an fyi.
i recommend checking out that link below for fasteners and raw materials as well.
it's www.mcmaster.com
i happen to be about 30 min from their warehouse. i bet i've spent over $500 there just for the rc cars. their service is awesome and so is their website.
Correct seaball, I beleive this is where I will be ordering my carbide bits from for my lathe. $3 a bit is very hard to beat.
