pro3
#1233
if you are into woven graphite, use HPI 73042 (front) and HPI 73043 (rear). with this, you can use the HPI shocks
#1234
i just bought a PRO3 kit and i have some questions regarding assembly.
I assembled the differetials and one of the steps were to insert a washer+short spring+washer combo into the hole into the middle.but at the sides the is a small hole and the washer comes out thru it all the time...
i also noticed that since it is sealed , it does nothing actually...what is it for ?did i do it right?
#1235
The washer/spring/washer should sit naturally beneath the hole. If you're having trouble getting it in, try threading the three parts onto a small screwdriver/allen key, and sliding them in that way.
It's VERY important those parts are assembled correctly, as they are what puts the pressure on the ball diff - without that pressure it'll just slip.
#1236
Pro-3 shock towers
The HPI graphite shock towers (either ones) fit perfectly with no other modifications needed.
#1237
Pro-3 tuning
Everyone;
Last weekend I tried changing the rear toe block(1-2-9) to 1 deg to try and get a little more top speed out of my car. I don't think that I really gained any more speed on the straight and it made the car a little looser in the rear (this was ok).
What I did do was change out my P2K2 (Dog) to a new Monster Stock Motor, tuned exactly the same as my P2K2. WOW what a difference in power. I really believe now that my P2K2 was just a DOG motor. It has NEVER been able to keep up on the straights no matter how I geared it.
This weekend I am going to try the Front One-Way to see if I can improve corner speed some.
Question for people who have the One-Way in their cars;
Did you make any spring rate changes when you installed the One-Way?
I've ran the countershaft One-way pulley, but didn't really notice any advantage to using it.
Thanks,
Thanks,
#1238
When running a one way you may have to go back to the 2 or 3 toe in the rear becasue of the extra speed the rear end in will follow the front to much and spin out. Try what you have know then chage if you need to , the more coner speed the better right. As for the springs I would agian try with what you have but stiffer will make it not as touchy when running the one way.
#1239
Rear Toe & One-Ways
TeamAE;
I already put the 2 deg toe block back in, figuring that it would be too loose with only 1 deg in back. I'm going to try 1 step stiffer springs in the F & R to make the car corner flatter.
Thanks for your help,
#1241
Chassis side plates
rc-zombies: which has a wider side plate for electronics, the Kai or HB chassis? i know you have had both. cheers
#1242
PPro3
the Hb is a bit wider, but the one from PRP is my next project!!! hehehehehehe
just want to hone my skills more with my TC3 before I go back to my Pro3 on steroids!
Lem
Lem
#1243
Re: problem fixed
Originally posted by lee82gx
turns out i did it wrong.rectified and now moving on.thanks sosidge .
i see ur on many forums...but so m I
BTw those tiny washers......i lost some so can i find replacements?from hardware shops?
#1244
Need more help(sosidge)
car's fixed.YAY!!!assembly is completed about 10hours i think.
now the elctronics are giving headache.i charged the batt. plugged in the esc to channel2 ,servo to channel 1 of receiver(futaba 2phka),batts to esc(LRP sprinter) but nothing happens when i press the throtle.WHY?is it bcos i havent setup my ESC properly?it has the continous green light meaning operating...but no response at all.....pls help
#1245
You need to set up the ESC following LRP's instructions.
