New - Hot Bodies 3.6mm Main Chassis >
Old 02-20-2008, 12:05 PM
Default New - Hot Bodies 3.6mm Main Chassis
Source - http://www.rc-area.co.uk/blog/?p=2462
"Racers needing a high-grip option for the Cyclone touring car don’t have to look any further than this extra-thick woven graphite chassis! At 3.6mm it is super stiff for firm footing on high-grip tracks like carpet. The chassis is CNC-machined to standard thickness where bulkheads and chassis posts attach. The six battery slots feature slots so you can move a 4- or 5-cell battery for your ideal weight distribution. You can also use split packs to adjust the weight balance incrementally. A wide range of carpet and high-grip racing options are also available, designed, tested and proven by the HB worldwide racing team!
If you need additional rigidity, check out the #61286 2.5mm Solid Upper Deck and #61289 Solid Middle Deck for high-grip racing surfaces! For the ability to quickly adjust to changing traction conditions at a busy race, use our #61283 Aluminium Chassis Post Set with Adjustable Torsion Control! Foam tyre racers will love the #61287 Low Mount Shock Tower for optimal traction when using low-profile foam tyres.
#HB61285 3.6mm Solid Main Chassis
HB61286 2.5mm Solid Upper Deck
#61283 Aluminium Chassis Post Set with ATC (Adjustable Torsion Control)
#61287 Low Mount Shock Tower (Front) (for foam tyres)”
k£v!n is offline
Old 02-20-2008, 12:29 PM
SammyZ's Avatar
Trader Rating: 138 (100%+)
i know your from the UK and all but you shoulda put this in the cyclone thread, there nice parts but they have been out for a couple months now
SammyZ is offline
