Team Magic E4 Thread >
Old 08-10-2009, 12:13 PM
  #2341
Originally Posted by wyd
10.5, 13.5 17.5 and I think 21.5 as well. Like I posted on the Ballistic thread I never ever liked Novak products but this one has me looking hard at getting one. Man saying that if you knew well is going to make hell freeze over.
I have to think they would be killer motor in the E4 for fit and maximum motor movement. That small end looks great for fitament in an E4. Black in color don't hurt either as I like black anodize.
LIKE A GLOVE MAN!
Just ask O.J.. LOL
John St.Amant is offline
Old 08-10-2009, 12:18 PM
  #2342
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Originally Posted by John St.Amant
LIKE A GLOVE MAN!
Just ask O.J.. LOL
wyd is offline
Old 08-10-2009, 01:39 PM
  #2343
Tabushi's Avatar
Hi guys,
Well, just opened the box.
What a nice view. 80% pre-mounted !!! lol !!!
Now, i do see that the servo is double-faced tape mounted, its that enough ?, or the aluminum servo mounts are a MUST BUY ?.
thanks,
Pato Concha
Southamerica
Tabushi is offline
Old 08-10-2009, 04:52 PM
  #2344
Originally Posted by Tabushi
Hi guys,
thanks,
Pato Concha
Southamerica
Rebuild the diff!!!
Old 08-10-2009, 05:43 PM
  #2345
Tabushi's Avatar
Rebuild the diff!!!
Just dissasemble and remount ?
thanks,
Tabushi is offline
Old 08-10-2009, 06:28 PM
  #2346
wyd
Tech Legend
wyd's Avatar
Ok here is my E4FS:
wyd is offline
Old 08-10-2009, 06:35 PM
  #2347
wyd
Tech Legend
wyd's Avatar
Hi guys,
thanks,
Pato Concha
Southamerica
I have the Yeah Racing alum servo mounts. They are only 7 bucks at my buddies shop at normal price. Tought to beat and they work perfectly on the E4. Almost look like factory and if i polished them they would look factory.
wyd is offline
Old 08-10-2009, 06:47 PM
  #2348
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
cant even think u'd buy 'bob' brand B. almost feel sick over the thought.
idk if tekins are any shorter, prolly not (but never lined em up side by side). orion is comin out with a shorter motor according to O.J. at Euros this past wk. idk if duo2 is any shorter. oh well time will tell
R
UltegraSTI is offline
Old 08-10-2009, 07:13 PM
  #2349
wyd
Tech Legend
wyd's Avatar
R
I know but even if I don't cre for a company I have to give credit when due and I think this time it is deserved. It is a great idea thats for sure.
I have ran worse and it is in my car in the picture. To me that is far worse.
wyd is offline
Old 08-10-2009, 09:34 PM
  #2350
thanks,
At least sand the rings , my kit diff was atrocious.
Old 08-11-2009, 06:31 AM
  #2351
Tabushi's Avatar
Sorry to be an ass on this John, im kinda new to electrics, sand the rings ?, hows that ?, and why ?.
What you think about the servo being helded by tape ?, i dont have access to servo mounts at least for this weekend, for the next race no prob but for now, i dont, would the tape resist ?
thanks,
Pato Concha
Southamerica
Tabushi is offline
Old 08-11-2009, 06:34 AM
  #2352
Registered User
UltegraSTI's Avatar
havent really been able to tape a servo down only to a car since the bolink legend IMO, u should be able to find mounts that will work at ur hobby store.
R
Old 08-11-2009, 06:42 AM
  #2353
wyd
Tech Legend
wyd's Avatar
thanks,
Pato Concha
Southamerica
Do you have access to stuff called Shoe Goo or Goop. You can put that on the servo and mount it on the chassis. WHen it dries it will hold your servo in place but allows it to removed later without damaging anything.
The diff rings are not flat from the factory. Remove them and wet sand them with 300 grit sand paper. They will be really shiney and smooth. Makes the diff really smooth.
wyd is offline
Old 08-11-2009, 07:15 AM
  #2354
thanks,
Pato Concha
Southamerica
Get some wet dry 600 grit sand paper and use the short diff half to ensure the drive rings are flat. sand in a figure eight and do both sides of both rings. This will ensure the diff balls have a consistent surface and makes for a much smother diff. Also it doesn't have to be so tight as before the rings were smooth. there is a vid somewhere of Jiles Groescamp rebuilding a 416 diff. You might want to check it out.
Old 08-11-2009, 07:26 AM
  #2355
Pro10noob's Avatar
Wyd,did you put spacers under the ball on the rear turnbuckle at the bulkhead side??
If not and you use the middle mount on the bearing holder on the rear the upper arms could bind on it.
This was with my car and that also solved my car breaking out at full throttle comming out of a corner.
cheers Roy
Ok here is my E4FS:
Pro10noob is offline
