FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF
#331
I myself own the ff-03pro, and boxstock it allready runs as a charm (well... with the exception of the plastic diff halves, they s#ck)
#332
Okay, now you've got me very interested! I've got my finger hovering over the 'Buy' button & I've justified the price tag with the fact that it has all the wings & widgets included (so no expensive 'hopping up'- I've got that), but you say that they are at extreme ends; so how does it drive?
I am taking both cars to TITC in Thailand for the FWD class (already has 40 entries with 2 months before the event) The track in Thailand will be far grippier than what we are racing here so it will be interesting
And $335? There are better prices than that if you know where to get them
#334
#336
Have had the FF03 longer so more time has gone into it. The Sakura is good as well. Am playing with a few different settings on the FF (diff oil) to see how much extra drive is available out of the corners.
#338
Yokomo YR-F2 Plate Chassis
To anyone that may be interested, I have put my Yokomo YR-F2 up for sale on Ebay. It is a rolling chassis (no electronics). Have a look if you're interested.
#340
I'm sorry that I don't have much, other than that, but it may help
#341
Hi Tommi, I raced the FF02 a very long time ago in the Eurocup & we had to run it pretty much stock. Although we were allowed oil filled shocks with a set height which made the wishbone arms level (oil I used was 40 weight) & I did alright & even beat some TL01s which were then mixed into the class...
#343
just one more question...
on its maximum gearing (20T pinion / stock gears), will the FF-02 keep up with a Tamiya FF-03 assuming motor, batteries, and ESC's are identical?
if not, will using a 3Racing speed tuned gear set with the largest allowable pinion work to close the gap?
#344
No I don't think the 20 will get you close enough with the standard gear set, the 3Racing speed tuned gear set will definitely help too. Apparently there is also a mod you can do to the chassis which allows you to use up to a 24 tooth pinion with the standard gear set.
