Old 06-23-2003, 10:59 PM   #1
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Default Monster pro, can be used out of the box ??
Hey guys got a new monster pro stock motor it says in the instructions this dont require any breaking in, so im assuming i can use this motor straight away right ?? Any recommendations before running it perhaps Anywayz hope you guys can help.
FUK_WRX is offline   Reply With Quote
Old 06-23-2003, 11:06 PM   #2
xxxtracer32's Avatar
i do a few simple things-
cut the com
check the hood alignment
check to see if the arm is in the center of the cans magnetic field
and break the bushings in even more
xxxtracer32 is offline   Reply With Quote
Old 06-23-2003, 11:52 PM   #3
Aurra Sing's Avatar
Yah, you can use a Monster Pro out of the box. Might not be fastest possible, but still fast.
Last weekend I wanted to save my new brushes for a carpet race later this week, so I ran my Monster straight form the box. It was still one of the fastest cars and set the fastest lap in Expert Stock.
Aurra Sing is offline   Reply With Quote
Old 06-24-2003, 12:56 AM   #4
FUK_WRX's Avatar
Default so you mean
So you mean to say i should cut the comm, and brake it in again with it orig brushes right ??
Old 06-24-2003, 02:24 PM   #5
Trader Rating: 28 (100%+)
Default Thats interesting aurra...
You set the fastest lap in stock?As I remeber mark,you got lapped by tq and winner of the amain and he ran a 6 month old Monster from my motor box.
racenut123 is offline   Reply With Quote
Old 06-24-2003, 04:22 PM   #6
Steevo's Avatar
Default Re: so you mean
Hi There Mate,
You can definately use the Monster Stock PRO version straight from the packet.
It has already been trued, Shimmed, had the bushes broken in and had the hoods aligned etc. This is what makes it the PRO Spec Version.
I use all my monster Stock Pro's straight from the Pack with excellent results.
Good Luck
Steevo
Steevo is offline   Reply With Quote
Old 06-24-2003, 04:28 PM   #7
johnny55's Avatar
Send a message via AIM to johnny55
Default Re: Re: so you mean
Originally posted by Steevo
Hi There Mate,
Good Luck
Steevo
What about the monster stock? (not the pro version) is it also just as good out the box? Or what tuning can I do to it to make it compete with a pro?
Johnny Hernandez
Fight on!
johnny55 is offline   Reply With Quote
Old 06-24-2003, 05:03 PM   #8
Steevo's Avatar
Default Re: Re: Re: so you mean
Hi Johnny55,
I have not had the non Pro Version Monster but I know that it has not had any of the extra tuning done to it.
So having said that I would recommend Trueing the comm, Shim the armature properly, Check the brush hood alignment and break in the motor properly. Also check the springs. I am not sure which ones come on the Non Pro version but if they are the standard thick silver ones then I'd go for a slightly lighter combo like red/green or purple/green with the lighter spring on the negative side...
Steevo
Old 06-24-2003, 05:10 PM   #9
johnny55's Avatar
Stevo thanks for your advise I have both motors and BTW the stock comes with black springs. Im just learning how to tune theise engines and the more I learn the fster I go thanks again.
Johnny Hernandez
Fight on!
Old 06-24-2003, 05:17 PM   #10
Aurra Sing's Avatar
Default Re: Thats interesting aurra...
I think I set the fastest lap... maybe I missed one of James' laps. It was a 12.2. Anyway, it doesn't matter. The point is that I used a Monster Pro straight from the box just fine. I just had bad qualifiers! If I had a clean run I could've TQ'ed. Oh well! In the main (sorry about the minor hack, John), I was closing up on James in the beginning, but one of the road rails got detached and flipped me over.
Old 06-24-2003, 06:12 PM   #11
FUK_WRX's Avatar
Talking change brush andnew cut
Thanks steve, how many runs you think i should do before changing brushes as well as cutting the comm ??
And as far as i remember the best brush to change it with is the reedy 767 right ??
Old 06-24-2003, 08:03 PM   #12
Default Again,Interesting........
You may be right Marc,you may have had the fastest lap.But consitency will wrap up a win for you.Taking the Tq from James that day may have been difficult for many including yourself.He was driving well.As for the minor race incedent on the first lap,well, for that not to happen will require all of us to let things work themselves out.Noone can win on the first lap you know.I know you got by me but then I got by you again and didnt bother to look back and was worried more about EJ then anyone else.Its all in good fun bro.Remember to keep it in perspective.1 fast lap is just that.1 fast lap. You gonna race again in 2 weeks?
Old 06-24-2003, 08:27 PM   #13
Steevo's Avatar
Default Re: change brush andnew cut
Well that depends on your preference. Some guys will skim their comm after every couple of races. Some will do it after every second race day. Others will do it once a month..
If your gearing is right and the motor is cleaned properly and regularly then you will get more runs from the motor before having to consider cutting the comm.
As far as the brushes go, once again if your motor is geared properly and your brushes are aligned properly then I will let mine go to about 1/3 of the original length before considering replacing. Some guys will change at 1/2 the original length.
If you do let them go right down you may want to consider a spring change and go one higher to what is on the motor currently. The smaller the brushes get the weaker the spring tension gets as the coil is allowed to unwind more.. Once again use your Dyno and your benchmark figure for the motor to help you decide....
If your brushes are not burnt from the motor getting too hot then leave them go. A dyno can be a big help deciding when to do what. Check your numbers when the motor is new or you have it going the way you want it to go, and use that as a bench mark.
Thats what I do anyhow but I don't claim to be an expert.. It just works for me...
Also as you mentioned the 767's are a good choice at the first brush change
Steevo
Old 06-24-2003, 10:30 PM   #14
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
just wondering but are all the dyno sheets on the motor diffrent?
mine are: what are yours?
rpm 20932 5.0v
power 68v 10.5k
Eff 47.4% 15.0k
Torque 103.5 Nmm
Pn: 2141
Calvin Ng is offline   Reply With Quote
Old 06-24-2003, 10:35 PM   #15
Steevo's Avatar
rpm 20932 5.0v
power 68v 10.5k
Eff 47.4% 15.0k
Torque 103.5 Nmm
Pn: 2141
Yes the specs will differ....
My RPM is 22,378
Torque 101.5Nmm
monster stock and monster hand out $20 yeaklet4 R/C Items: For Sale/Trade 0 04-15-2007 06:51 PM
Ofna monster Pitrate 1/8th Monster truck Boostd2valve R/C Items: For Sale/Trade 4 02-25-2005 09:31 AM
Paradigm monster VS Fukuyama Monster FUK_WRX Electric On-Road 127 06-02-2004 04:48 PM
Monster stock / Revenge of the monster Klaus Electric Off-Road 1 03-08-2004 07:34 AM
Trinity Monster vs Fantom monster xray racer Australian Racing 15 06-24-2003 04:13 AM
