Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 02-18-2011 | 10:52 PM
  #14431
Dan's Avatar
Dan
Whatup Syde?! What you been up to lately mang!
Dan is offline
Old 02-18-2011 | 11:01 PM
  #14432
Hey Dan. I'll PM ya.
Sydewynder is offline
Old 02-18-2011 | 11:33 PM
  #14433
monkeyracing's Avatar
R/C Tech Elite Member
Originally Posted by MUDVAYNE
Does anyone here ever take apart the bearings and clean the greese out of them and put in a lighter oil? and if so, what oil?
We've all got an answer for this one, I'm sure.
I like the Avid RC bearing with the rubber seal on one side and the metal on the other. I pull the rubber seal and throw them in a jar of brake kleen for a day or so.
After I pull them out and dry them, I use a single drop of motor oil, in this case Mobil 1 0W40.
Run the non sealed side on the inside and they'll last a long time.
Jim
monkeyracing is offline
Old 02-18-2011 | 11:59 PM
  #14434
Put an 8.5 turn hobby wing brushless motor in my mini. Gens ace 4000 mah lipos. It was ALOT of fun until I stripped something. God was it fast. I'm hoping it's just the pinion so i dont have to take the whole car apart to get to the diff.
jmhub1979 is offline
Old 02-19-2011 | 03:20 AM
  #14435
pimoy_boy's Avatar
hi guys, planning to get mini car for the first time
need your advice which model to buy between M03 , M04 , M05, M06 and essential hop-ups for starter. Im looking for easy and fun to run
your input is very much appreciated
thanks
geri
pimoy_boy is offline
Old 02-19-2011 | 04:15 AM
  #14436
k_bojar's Avatar
you probably stripped the spur gear inside, or one of the counter gears since they are all plastic
sorry, but i think you're gonna have to open up the chassis
k_bojar is offline
Old 02-19-2011 | 05:03 AM
  #14437
rccardr's Avatar
Yes.
Lighter fluid.
rccardr is offline
Old 02-19-2011 | 09:02 AM
  #14438
trerc's Avatar
I use to take the time to piss with taking the seals out of bearings or putting them in a bearing blaster to blow the grease out and relube them with lighter oil but in all honesty it's a waste of time not to mention the seals are fragile and you generally won't get them back in without biding the bearing anyway. Seriously just take the car out and put it down on the track and run it, the bearings will free up quickly. I don't clean bearings either, I order all my bearings from Avid, when they get gritty I pitch em, they're a buck. If bearings do need relubed I use drywax products like these.
http://www.whitelightningco.com/products/index.htm
http://www3.towerhobbies.com/cgi-bin...?&P=8&I=LXTMF4
trerc is offline
Old 02-19-2011 | 09:10 AM
  #14439
Laguna Bozo's Avatar
Default Waitin' on weather
Like most everyone on this forum. I spend a lot of time messin' on my toy cars. Trying to be competitive requires dedication. I haven't taken any four-wheeled toys to bed in a long time, but y'all know what I mean. Spending time messaging bearings is one of the least productive projects you'll tackle!
Every possible tweak you can think of, I've tried. When a bearing gets "crunchy", toss it. At a buck each, new bearings are the only way to go
Laguna Bozo is offline
Old 02-19-2011 | 11:59 AM
  #14440
thanks
geri
The M-03 is the easiest car to deal with for your first mini. They are very easy to work on and fun to drive.
I would say the most essential hop ups are better axles, shorter springs and good tires.
Everything else is just shiny.
Old 02-19-2011 | 12:00 PM
  #14441
BumFacedGoat's Avatar
thanks
geri
i run an m03. almost unbrakeable and really ez to work on. a lot of my buddies run m05's but i reckon they arent very ez to work on.
m04 and m06 are rwd, much harder to drive
BumFacedGoat is offline
Old 02-19-2011 | 12:35 PM
  #14442
i have both M03 and M05 , after 1st having problems with the M05 i have worked hard on it and now it is AS quick as the M03s in the club ,
I love it and it is more prodictable then the M03 and more consistant
all though no quicker , i like it more
and as for mantinance i can strip the gearbox and rebuild it as quick as i could with my M03 so there is no time worries there
M05 for those who like to tinker M03 fo those who like to build and drive
sidecarphil1 is offline
Old 02-19-2011 | 12:54 PM
  #14443
trerc's Avatar
thanks
geri
Buy an m03 Swift, http://www3.towerhobbies.com/cgi-bin...?&I=LXMFV9&P=7
Some universals. http://www3.towerhobbies.com/cgi-bin...?&I=LXMFV9&P=7
TRF shocks w springs. http://cgi.ebay.com/54000-Tamiya-M-C...item2eb272d4a3
Orion Rocket Lipo. http://cgi.ebay.com/Team-Orion-Rocke...item35b0097bb6
and some bearings and you will be set with a capable mini.
trerc is offline
Old 02-19-2011 | 01:38 PM
  #14444
Hi, I'm working on my mini. It is currently 225mm wheelbase, but I'm going to shrink it to 210mm. I need a body-suggestions? Obviously something with a "nose". Wt. is 1330 grams, width(trac) is 167mm. The weight is not completely set as it's going to get a new chassis out of .125 G10 versus .093(to much flex) and a 2s lipo. Thanks, Don
Attached Thumbnails Tamiya mini cooper-p1010001-2.jpg   Tamiya mini cooper-p1010002-1.jpg   Tamiya mini cooper-p1010003-1.jpg   Tamiya mini cooper-p1010004-1.jpg   Tamiya mini cooper-p1010005-1.jpg
DLS II is offline
Old 02-19-2011 | 01:47 PM
  #14445
playmo-FR's Avatar
your project was realy great !! very good
playmo-FR is offline
