Tamiya mini cooper
Hi all. I'm in Australia, and I am looking at buying a new body shell formy m-05. I havelooked aroun online but I am struggling to find a store to buy from. Can any one help me with a web address of an online store that sells mini stuff. I need tyres and shock as well as the body, so if I could fond one web site that has it all, that would be great.
thanks in advance
ackie
thanks in advance
ackie
What body are are after Matt?
Are you after the normal mini one or something else?
Metro Hobbies in Box Hill has bodies, but get the shocks from RC-Mushroom or the like.
Tower hobbies also has a decent selection of bodies.
thanks in advance
ackie
thanks in advance
ackie
Also have the Mini shocks as well as nearly every brand of tyre available
Try www.feralbatteries.com.au
the guy at m-chassis has lots of mini stuff also, and is in Australia
Need some help with a TAO3 ball diff install. I assembled the diff, reassembled the car and when i throttle up it pushes the dog bones out disengaging from the front axles. I tried removing the rubber O rings because i thought there was a clearance issue and it didn't help.
Any suggestions?
Thanks in advance for any suggestions
Any suggestions?
Trade 20T pinion for 19T
So i know this is kinda random...but I was wondering if anyone wanted to trade a 19T pinion for my 20T?
I bought the 20T/21T pinion combo and my M04L only uses a 17, 19 or 21.
So since I'll probably never has a use for a 20T, I figured maybe someone would want to trade for it. (If not...a 19T is only like 5 bucks, so its no biggie!)
i got a new 19,21 you could have
BUT
i live in holland and the shipping would be more than buying the pinions
BUT
If you're already running the TA03 outdrives with the TA03 diff then it should work ... do you think you could post a photo showing the front knuckle, dogbone, outdrive all in the car, that might help.
Quick question too: Do normal 60D tires fit on any of these 3racing wheels?
http://www.etamiya.com/shop/tamiya-m...1_582_610.html
Last edited by Steve420; 04-03-2010 at 10:41 PM. Reason: ask a ? instead of dbl post
Stupid Atlantic Ocean has to be all up in the way!! I do appreciate the thought,,,would have been nice if you were closer!
the plated blue versions from the M03r are a bit too soft
my 3racing rims are a little bit wider, 25mm wide, 42.5mm dia
May still not be suitable for 60's ?
hope that helps ??
Thanks for the help Tim. Unfortunately my camera is down, but I tried adding some silicone donuts to the outdrives and it helps keep the dogbones in the front axels better. I still experience the dog bones pushing the bearings out of the front C Hub when i make sharp turns. Do you think extra donuts in the out drives would cure this?
See that red Mini on the left? Wanna know how quick it goes with a 5.5 brushless in it?
And the orange Mini in the centre? Maybe we finally know just who the Stig really is now...
And who can do a knife-edge manoeuvre (unsuccessfully) with a Fiat Abarth?
All those questions answered, PLUS lots and lots of new Minifan additions too.
Right HERE on rc-mini.net
what tires u normally use in mini club races?
