Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 01-14-2010 | 10:35 PM
  #11266
Originally Posted by caltek1
doriftu,
I used AW grease on the diff plates and 3mm balls. However I first sanded the diff plates to make them flat and I used Much More Thrust bearing grease on the thrust. I changed the balls to the carbide 3mm Tamiya balls.
Make sure you do not over tighten the diff nut. I have already stripped a 2mm locknut, split a thrust bearing and snapped a screw.
I am now trying some other Tamiya parts in the MO5 diff, which are stronger.
Later,
Calvin.
my 3Racing ball diff snapped the screw mid Qualifying , took it appart and replaced it with a TRF415 part , as tight as i think it needs to be PERFECT
sidecarphil1 is offline
Old 01-16-2010 | 03:46 PM
  #11267
edhchoe's Avatar
Default New r56 mcs body for my not so new m03l chassis.
The white stripes look out of place... I need to find some black electrical tape. But this is the color combo my 07 MCS was. I miss it occasionally.
edhchoe is offline
Old 01-17-2010 | 12:38 PM
  #11268
caltek1's Avatar
Default MO5 Ball Diffs
sidecarphil1,
I have found the screw is not the problem,(unless you really over tighten, then snaps) but the inferior 2mm locknut is the cause of the problems with the Tamiya and 3Racing MO5 ball diffs.
I have fitted two locknuts into my 3Racing MO5 ball diff and will give it a try. I am hoping that the extra nut will give more purchase area to the screw and prevent stripping.
On the Tamiya ball diff I have removed the nut holder and replaced with the 416 diff screw mount and applied loctite.
I am testing these to see how durable they will be. I am only tightening my ball diff until I can not move the diff gear when using two allen keys. When fitted into the car the diff feels slightly tighter than a gear diff, however does not slip.
Later,
Calvin.
caltek1 is offline
Old 01-17-2010 | 12:52 PM
  #11269
sidecarphil1,
Later,
Calvin.
my screw snapped just after the head of the bolt
i use the TRF screw and nut now , no problems , and mine is REALLY tight !!!
was racing old school this weekend , stock M03 swift (apart from shocks) and C cells , went well , was 3rd in the first A main and the battery went flat in the 2nd A main !!!! 30 seconds to go !!!! BUGGER IT !!!!
never mind GREAT DAY
Old 01-17-2010 | 03:47 PM
  #11270
mcdogboy's Avatar
Quick Q
What size bearings do the upgraded alloy m03/4/5 front hubs use?
It is certainly not the same size as the placcy ones.
mcdogboy is offline
Old 01-17-2010 | 09:31 PM
  #11271
VooDooPH's Avatar
Originally Posted by tony gray
An old school Toyota MR2 shell in 210mm from Team Atlas. Should fit an M05, forget about an M03 though..
i like! where can i get one?
VooDooPH is offline
Old 01-17-2010 | 09:46 PM
  #11272
stulec52's Avatar
Default Selling my 05 pro
Hi guys
Since I'm not getting to run much right now, I'm selling one of my Minis.
This is my new M05 PRO that I built for the last round of our series.
It TQ'd there, so it can't be bad !
Only other runs it has had is a couple of practice runs at the club, all on carpet, to set it up.
Will come complete, highly specced, lots of hop ups.
stuff like ; ball diff ( + parts to make geared one too)
Tamiya M chassis alloy shocks
steering link changed out to 3R one.
all good stuff.
KO servo
GTS Speedo
motor
no receiver as I think I'm the only one around here running 27FM !
Large spares package.
box
manual
body shell
and anything else I can find that I think you might need
looking for around $300CDN
thanks
Stu
stulec52 is offline
Old 01-18-2010 | 11:19 AM
  #11273
Pro10noob's Avatar
Hope i am in the right section here but i have a small question for you guys.
Will the Alfa Giulia Sprint GTA body fit the M03M???
If so where can i buy a replica of this body if it is been made.
Looked on Fleebay but you hardly see the body there,only the complete car and that is a M04.
cheers and thanks in advance Roy
Pro10noob is offline
Old 01-18-2010 | 11:51 AM
  #11274
k_bojar's Avatar
Unfortunately, you can only get that body via the whole kit anymore
been looking for the body alone myself
k_bojar is offline
Old 01-18-2010 | 01:02 PM
  #11275
I've received a set of Muchmore Sweeps (25s) pre mounts with soft (pink) inserts. Can anyone offer advice regarding running the M05 on the same inserts all round on carpet?
Should I glue them up and run them or is that asking for trouble and I should swap the fronts out for a medium insert?
V1nce is offline
Old 01-18-2010 | 02:30 PM
  #11276
gashuffer's Avatar
Have you guys seen this one yet?http://www.tamiyausa.com/product/ite...oduct-id=58454
gashuffer is offline
Old 01-18-2010 | 02:51 PM
  #11277
Pro10noob's Avatar
But will the body fit??
Won't it sit to high??
cheers Roy
Old 01-18-2010 | 03:41 PM
  #11278
mcdogboy's Avatar
Originally Posted by gashuffer
Yeah, and am still surprised Tamiya would do a RWD car on a FWD chassis.
mcdogboy is offline
Old 01-18-2010 | 04:24 PM
  #11279
gashuffer's Avatar
Buy a M04. Problem solved.
Old 01-18-2010 | 05:09 PM
  #11280
Originally Posted by gtfour93
Both dampers should do the job but with 53571, you get the aluminum spring perch. I believe they are a little thinner than the plastic ones, for more lower center of gravity. Tamiya also offers these hop-up spring perches in anodized blue.
Do you know what the Tamiya part number is for these aluminium spring perches? I have been looking for some for my TRF dampers (42102) but can't find them. Any help is most appreciated. Cheers!
XanderBingo is offline
