Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 05-31-2015 | 12:41 PM
  #23821
AngryRog's Avatar
Originally Posted by Granpa
Made it out to the track today for the first time in about a year and ran a couple of batteries. It was great to visit with my old friends, swap stories and gossip, and just hang out. I really missed them and just didn't realize how much.
Driving the car was a struggle tho, cause the track had changed and I just took a car and a few batteries---no tools. Today was just to hang out at the track for awhile, not to waste today working on cars.
Glad to see and talk with you yesterday.
AngryRog is offline
Old 05-31-2015 | 01:17 PM
  #23822
sakadachi's Avatar
Not sure how I ended up with such a long cut on my M01 body for a moderate speed crash into a foam protected shelf leg. My other M03+ Rover bodies would've probably come out unscathed.
I suppose being a 15-20yr old body, the pc may have degraded and became more brittle/flaky? The cut goes straight down the orange line.
http://www.rctech.net/forum/members/...-m-fix-cut.jpg
I thought about using liquid adhesive with drywall mesh, but if I crash again and the paint chips under the pc, I won't be able to fix it. So used 3 layers of foil tape as usual.
http://www.rctech.net/forum/members/...m-fix-back.jpg
The tape holds well so the outer decals are more for cosmetics to hide the line.
http://www.rctech.net/forum/members/...0811-m-fix.jpg
Here's foil tape if anyone's interested. It's adhesive backed, conforms to shape very well. Does not stretch and can sustain about 180F of heat. If used in layers it can sustain some level of impacts. Not permanent like adhesive + mesh, but there is zero dry time, no toxic smell, easy to use, can take it to the track or parking lot for quick fix, etc.
http://www.amazon.com/Scotch-Aluminu...ywords=3M+3311
Thinner variant.
http://www.amazon.com/3M-Foil-Tape-3...=aluminum+tape
sakadachi is offline
Old 06-01-2015 | 08:18 AM
  #23823
Thumbs up
Great to see you at the track last weekend Bob. Lets do it again soon!
madjack is offline
Old 06-02-2015 | 06:05 PM
  #23824
The Big Wig's Avatar
Originally Posted by EricP
Some pics of the MF-01x build
Hi, so the seal around the front gearbox looks very good. Is it the same at the rear? What is the biggest motor pinion U can use and what's the FDR? And I'm guessing TL01 gears means TL01 high speed gears to?
The Big Wig is offline
Old 06-02-2015 | 07:59 PM
  #23825
monkeyracing's Avatar
R/C Tech Elite Member
Stock TL01
19T - 7.96
21T - 7.20
23T - 6.57
Speed tuned gear TL01
19T - 5.95
21T - 5.39
23T - 4.92
Have I mentioned how awesome the Xevo is yet?
monkeyracing is offline
Old 06-02-2015 | 08:17 PM
  #23826
tony gray's Avatar
Xevo is only awesome if you don't have a TOP Sabre Mini....
tony gray is offline
Old 06-02-2015 | 08:35 PM
  #23827
Don't make me come over there, Tony. I'll be jet lagged and extra cranky.
Old 06-02-2015 | 09:03 PM
  #23828
How does it compare with the Atomic????? Is the TOP sabre the one that comes in a 4WD and as a front driver???? I'd heard they were pretty special.
Granpa is offline
Old 06-03-2015 | 12:17 AM
  #23829
tony gray's Avatar
It comes as both Bob. Full-on 4WD and also as a dedicated FWD.
They set the standard as far as we're concerned, they are the benchmark by which others should be judged.
Old 06-03-2015 | 05:21 AM
  #23830
sakadachi's Avatar
Tony would you please post a link of said top 4WD Sabre?
TIA!
Old 06-03-2015 | 05:24 AM
  #23831
caltek1's Avatar
What sort of link are you after?
caltek1 is offline
Old 06-03-2015 | 05:45 AM
  #23832
sakadachi's Avatar
Info for purchase if it's something that sparks my interest.
I've been on a look out for more 210mm 4WD M-chassis.
Old 06-03-2015 | 05:47 AM
  #23833
Rodarbal's Avatar
TIA!
Here's Top Racing:
http://www.top-racing.jp/
Here's the 4wd Sabre Mini (as opposed to the standard 1/10 4wd Sabre):
http://www.top-racing.jp/Eng+JP/Cate...WD%20Mini.html
What other M-scale chassis interest you?
Rodarbal is offline
Old 06-03-2015 | 08:10 AM
  #23834
patorz31's Avatar
http://rcmarket.com.hk/product_info....ducts_id=15638
Rc Market has them I don't know of anyone who sells them in the states.
patorz31 is offline
Old 06-03-2015 | 08:24 AM
  #23835
If I could have found the FD nearly as cheap as I found the Xevo, it would have been a consideration. Between price, the boxes full of spare parts I've got and sheer, dumbed down simplicity, the Xevo wins.
Mind you, the Sabre does have one thing going for it, besides being well built and incredible handling - it has red anodizing.
