Peak Voltages: 5 cell and 6 cell >
Old 01-01-2008, 07:27 AM
Island Losi's Avatar
Default Peak Voltages: 5 cell and 6 cell
what are considered good peak voltages in 5 and 6 cell?
Island Losi is offline
Old 01-01-2008, 07:35 AM
t4m1y4niac's Avatar
6 cells @ around 9.3V
5 cells...never know..
t4m1y4niac is offline
Old 01-01-2008, 07:47 AM
6 cells: 9,3-9,5v
5 cells: 7,7-7,9v
Jan Larsen is offline
Old 01-01-2008, 07:55 AM
thanks
happy new year!
Old 01-01-2008, 10:09 AM
trailranger's Avatar
I really don't go by what the charger has declared peak since it varies too much. I go by the "race" voltage which in many cases is between 1.39V to 1.44V per cell after disconnect from charger. So a good pack for me would have about 8.6V before I set it on the track. The charger peak value will always be higher since in order to charger a battery it needs to create a higher potential to push powre into the cells. The higher the charge rate in amps the higher the chargers peak voltage will be to create that push.
trailranger is offline
Old 01-01-2008, 10:32 AM
joe of loath's Avatar
charging peak: 1.67 per cell
no-load peak: 1.38 per cell
so basically, this is 10.02v on the charger for a 6 cell pack, and 8.28v when measured with a voltmeter straight off the charger.
hope this helped
Joe
joe of loath is offline
Old 01-01-2008, 11:34 AM
thanks again for the replies. what im doin is making some of my 6 cell packs 5 cell. just wanted to kno what to look for when i cycle the 5 cells. i just take out the cell that consistantly 'dumps' first on the DPD. mainly making some packs for pratice but i just incase they are good for racing i wanted to know what to look for.
Old 01-01-2008, 11:35 AM
hope this helped
Joe
my packs are usually around 8.6 after peak.
Old 01-01-2008, 11:36 AM
that sounds about right then. those figures are a bit old...
Old 01-01-2008, 11:47 AM
.........meaning peak at 9.1-9.4 and settle down to around 8.6
Old 01-01-2008, 06:11 PM
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
With todays cells for 6cell sedan classes, i dont look at runtime or really how much milliamp going into the pack, I keep track of the peak and no-load voltages.
BSchorr is offline
Old 01-05-2008, 03:33 PM
Jack Smash's Avatar
Trader Rating: 35 (100%+)
The peak voltage is just how much voltage was needed to push the amperage past the resistance of the cell. A higher peak voltage just shows that that pack has more resistance than a pack with a lower peak voltage.
Jack Smash is offline
