Old 05-24-2003, 11:36 PM   #1
Default Electronics question:
If I wanted to switch to another radio that I have, can I just swap out the receiver OR do I have to swap out the servos too?
Specifics: TC3 RTR came with a crappy hitec. I want to use my Futaba radio. Can I, or do I have to switch to the Futaba servos also?
RoadRat is offline   Reply With Quote
Old 05-25-2003, 12:12 AM   #2
Super Moderator
Grizzbob's Avatar
No, as long as the reciever plugs on the servo are set with the correct wiring pattern(which they commonly are nowadays), you can leave that servo in there if you like & it should just plug directly into the different reciever. Just be sure to test it on a stand before you put the car down to run after changing everything out you want(you can never be too careful)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 05-25-2003, 10:45 AM   #3
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hitec servos will plug right into Futaba gear with no wire changes or plug changes. If you want to run Futaba servos with Hitec radio gear, you will need to cut the ear off of the Futaba plug for them to fit. I believe all of the servos made now have the same wiring so they will work with just about any reciever, not 100% sure if that goes for KO, and the old Airtronics plugs (not made anymore that I know of) will need to be changed around as well.
Old 05-25-2003, 03:03 PM   #4
Super Moderator
Grizzbob's Avatar
Yes, it goes for KO as well now. They switched over to the Futaba "J" pattern about 6 1/2 years ago or so. I learned it the hard way when I bought a newer KO radio in '97(had been using an original analog EX-1) & the EX-11 I bought had the new wire pattern but I didn't realize until I plugged everything in & tried turning it all on & ended up burning out the voltage regulator on my ESC(but the reciever & servo were unhurt). Nowadays, it's all so much simpler, just plug in & have fun....
Bob Seay
Go Pokes!!!
Graphite + Electronics Wire Question aN4rK1 Electric On-Road 6 04-28-2006 01:44 AM
Competition Electronics Linear Turbocharger Question? crACkeD ChaSsiS Electric On-Road 13 02-13-2005 01:42 PM
Technical electronics question M.J Electric On-Road 10 02-08-2005 10:20 PM
Wireing and Electronics Question Kall Electric On-Road 10 04-06-2004 08:26 PM
Quick electronics question........ DJ_GenR8 Electric On-Road 2 04-21-2002 01:52 PM
