Converting Computer Power Supply. Who got it to work? Who didnt? >
Old 05-21-2003, 06:10 PM
Registered User
Calvin Ng's Avatar
Default Converting Computer Power Supply. Who got it to work? Who didnt?
I know a couple of people got it working
but who didnt????
http://www.magicookie.com/prodigy/psupply.htm
Calvin Ng is offline
Old 05-21-2003, 10:42 PM
I did. I wired 3 PC power supplies in series. 15 volt/75amp output.
acloco is offline
Old 05-21-2003, 11:54 PM
I have used a 300W AT supply for years. Had it modified to give out 15V instead of 12 (don't ask me how, I'm not strong enough in electronics to explain. Something to do with changing the resistors in feedback voltage divider). I have not found a single reason to quit using it.
olev is offline
Old 05-22-2003, 03:33 AM
Cole Trickle's Avatar
I've done it for a half a year ago. Works nice.
In addition, we have about 20 in our club, which also work fine.
Cole Trickle is offline
Old 05-22-2003, 06:42 AM
che
che's Avatar
I have been using one for about 2 years now.
Nice clean power output.
I use the 12volt for chargers, etc. and 5 volt for running my lathe and motor break in.
che is offline
Old 05-22-2003, 05:32 PM
Registered User
Calvin Ng's Avatar
why would you need 75 amps????
Old 05-22-2003, 05:39 PM
dux
I have. Only cost me resistors and some jacks. Nice 19A thing.
dux is offline
Old 05-22-2003, 05:41 PM
dux
Forgot to mention: the power supplies that don't work too well for conversion are the kinds that have the switch installed in the unit already. Most of them have some funny way of turning on the power, and makes it a hassle to wire up. So make sure the switch is on a harness.
dux is offline
Old 05-22-2003, 07:43 PM
hehe...bigger is better?? hehe
Actually used it to power a CE TD45.
I also use the power supply as a home power supply.....for the workbench.
acloco is offline
Old 05-22-2003, 07:47 PM
rough512's Avatar
I think the AT power supplies are preferable for conversion. I have also converted one for a Novak Millenium. Then I got a Tekin BC112 and shelved the power supply.
I'd really love to see how the 12V output can be jacked up to 18V or 20V. The Tekin Manual says a higher power supply voltage gives better results than 12V
rough512 is offline
Old 05-31-2003, 12:53 AM
found this thread and did something...
well this my version here.....
Attached Thumbnails Converting Computer Power Supply. Who got it to work? Who didnt?-psu-conversion.jpg
treecom is offline
Old 05-31-2003, 09:52 AM
Registered User
Calvin Ng's Avatar
how many amps are you getting out of the thing
Old 06-01-2003, 08:46 AM
i don have the stuffs to test that but i have been charging my batts at 6 amps and running a cooling fan thats drawing 0.5amps and its still very cool and stable....
treecom is offline
Old 06-01-2003, 02:12 PM
Nice work.
Old 06-01-2003, 06:30 PM
Registered User
Calvin Ng's Avatar
whats diffrent between yours and the other?
