T*Star12
Old 02-24-2009, 07:28 AM
  #91
Originally Posted by adam lancia
That looks real nice Alf!
It looks like it finally is as strong as i wanted and don't break, and the removed X make i lighten to.
Alf
alf.skaar is offline
Old 03-23-2009, 02:14 PM
  #92
Default Frontend
Have a look at this
Alf
Old 03-24-2009, 05:59 AM
  #93
Old 03-24-2009, 03:03 PM
  #94
Have teste it on the track today, worked greeat, will have to rcheck it
to see if anything have moved.
Alf :-)
Old 03-24-2009, 03:42 PM
  #95
Are those middle turnbuckle links floating or are they fastened to the upper front chassis plate somehow? What do you notice different with your front end versus a standard Associated-type front end? Looks like a lot of fun designing and building!
adam lancia is offline
Old 03-25-2009, 12:13 AM
  #96
They are floating after you release one or two screw depending one what you want to adjust.
I think it drives better.
Compare to a standard AE i don't have any reactive caster sow the car will steer
on the smallest input on the steering wheel, and you drive it into the corner.
I don't like reactive caster on a very small track it gives more steering that is
true, the new AE front is using bump steering to, this in combo whit reactive
caster give massive steering, we run on bigger track here and the corners are longer this make the car steer, don't steer, steer, this is a bit how the
reactive caster
work true the corner, depending on tyre grip level and length off the corner.
This is for racing, the track i test on is small and high grip, and it works great!
at this track, I will test with Somme reactive caster.
Designing is fun, if i ever start whit RC racing again, the first thing i will
get is a CNC mill. then car, radio, etc. :-)
I try to make a design that don't bend get out off alignment,
this way i have to screws holding the links now.
This camber and caster adjustment added 2.6 grams to it
show I will now try to make the arm lighter it is better that they
flex and flex back then bend something in impact
Alf
Old 03-26-2009, 02:05 AM
  #97
Default New Motor Pod
Alf
Old 05-29-2009, 03:26 PM
  #98
I have repost the images.
I may missing some
Alf :-)
Old 04-28-2010, 01:00 AM
  #99
Default Lipo
Old 09-01-2010, 04:47 AM
  #100
Default Las Vegas 2010
:-) bring it on
Old 09-19-2010, 03:18 PM
  #101
the new chassis is done, picture soone. Alf
Old 09-19-2010, 04:03 PM
  #102
Khador12's Avatar
Can't wait Alf get those pictures up!
Billy
Khador12 is offline
Old 09-19-2010, 04:15 PM
  #103
Wow that was fast...must have started cutting the day after you got back
InspGadgt is offline
Old 09-19-2010, 04:56 PM
  #104
cuted yesday, had to do new drawing first, tbar
14mm wide. Alf
Old 09-21-2010, 12:52 AM
  #105
Alf
