Like Tree86Likes
Hpi Pro 4
Old 05-12-2005, 02:13 PM
  #11236
Originally posted by barnacle
Thanks. That is what i needed!
Hmmm...Mike....on this thread. Did I miss something?
Proteus is offline
Old 05-12-2005, 09:17 PM
  #11237
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Just got a set of TIR World's Edition CVD's. How durable are these and are they worth the $40? -JB
JayBee is offline
Old 05-12-2005, 09:27 PM
  #11238
Registered User
I've been running them a couple weeks now and they are really durable. More durable than the aluminum MIP ones, and IMO less prone to snapping than steel ones would be. Also much lighter than the steel ones (they feel like the aluminum ones to me, they have to be very close.)
Worth the money in my opinion. I've had some really hard hits recently where I've stuffed a single front wheel while making a turn at high speed, and they have not bent. One might be a little tweaked, but it's less than .001" of wobble. Today I stuffed the car hard enough to break a ring gear, the drive shaft outdrive on the front gear box, my front arm, and split my wheel and the CVD didn't bend at all. It's a little chewed where it goes into the outdrive, but not bent.
The damage done to the car would have totally wrecked the MIP CVD. I ruined both mine with much less contact than what I did today, so they totally have my support.
Desolas is offline
Old 05-12-2005, 09:29 PM
  #11239
JayBee's Avatar
Post
Thanx for the report ... -JB
JayBee is offline
Old 05-12-2005, 09:30 PM
  #11240
axel's Avatar
The tc4 mip ones are also alot better than the MIP pro4 ones. They are much bulkier, they also feel alot more lighter in my opinion. I haven't ran them yet, but it's already been proven. The only problem is that it is blue, but who cares
axel is offline
Old 05-12-2005, 09:43 PM
  #11241
fjm9898's Avatar
what do you think is better for taking hits the TIR World's Edition CVDs or the IRS big dawg CVDs
fjm9898 is offline
Old 05-13-2005, 12:19 AM
  #11242
Registered User
I bent the IRS ones with little effort. They held up for longer than the MIP ones, but still ended up bending. That and they only have one set of holes drilled in the CV cup if I remember right, where the TIR's have two sets so if you round one out you can change the pin to the next set. I'm not buying CVD's unless they have the cup drilled twice, it just doesn't make sense to only have one pin hole. It's the part that wears out if you don't manage to bend/break the bone.
So just for taking hits, I'd say the TIR's hands down are better; plus they match the car. Sounds petty, but I'd rather keep it purple. Kind of irks me that I'm running blue IRS axel nuts actually.
But this is all coming from someone who manages to snag a board under power at least once a week. If you don't hit stuff often, or can get off the throttle before you hit, the less expensive ones will work just fine. If the TC4 MIP bones will work, they may be even better than the IRS ones; much thicker. For a TC3 it could be just the ticket, I'd just rather not have a black, blue, and purple car.
Desolas is offline
Old 05-13-2005, 06:21 AM
  #11243
Default Pro 4, Hard to Set-up?
Hi guys,
I recently bought a SDW but although I'm sure its great car to race I won't be using it (looks so beautiful in my pitshop) so I might be getting a Pro 4 for racing but I heard all this stuff about how hard it was to find a good set-up, is this true or just a rumor?
Thanks!
Tbevofreak is offline
Old 05-13-2005, 07:42 AM
  #11244
Skill's Avatar
I've had the TIR Worlds edition CVD's in my car for 3 meetings now and no wear so far. They look very impressive and are a fair bit lighter than the standard aluminium CVD's, I only got them for the front though.
When I first got my Pro 4 it didn't take me long to get a pretty decent setup from the stock, infact I don't think I changed much at all, but it all depends on your driving style. Generally though the car is very well balanced and does exactly what you expect it to do when you change the setup, easy to setup and easy to drive, it's a great car...but then again, I guess I am a bit biased towards it
Skill is offline
Old 05-13-2005, 08:07 AM
  #11245
Registered User
I agree with Skill, the car reacts to changes like it should. You alter a setting and you notice a huge change.
When I setup my car initially the stock settings were kind of off for my track, it took about two 2 hour sessions for me to get the car dialed in. But it wasn't hard, it was pretty entertaining being able to play with the car and learning how it reacts to stuff. I made changes everywhere just to see how it would react, changes that would do nothing when I had a TC3. Because of that it is easy to really screw up the car's setup though, if you set something off, the car can be really way off and unstable on the track. Unlike other cars where you can make huge changes and your not sure if it did anything. Mine still needs a little tweaking here and there, but is probably 90% dialed.
Desolas is offline
Old 05-13-2005, 08:52 AM
  #11246
pitshop's Avatar
Trader Rating: 56 (98%+)
Default Re: Pro 4, Hard to Set-up?
Originally posted by Tbevofreak
Hi guys,
Thanks!
Then I suggest you pick up another SDW to race with
well, the LCG is coming out (converts any old version of the SD to SDW specs) so that could be another option...
pitshop is offline
Old 05-13-2005, 11:08 AM
  #11247
Yeah! well I dont think I will find one anymore now unless I pay over 500$ for it wich I wont do (got mine for 429$) but your right the LCG might be a hot racer but you need loads of other parts
Sine I build the SDW I ve become a Yok fan, such a great finish and quality
The pro 4 is still a good choice, I have to compare price with a built LCG SD
I still cant go to belt cars although the BD and the 415 MS are catching my atention, great cars too
Old 05-13-2005, 11:09 AM
  #11248
fjm9898's Avatar
Desolas, just FYI IRS big dawgs do have two sets of holes
but alright i gess after i bend up my irs ones enough ill have to give the TIR ones a try
fjm9898 is offline
Old 05-13-2005, 04:11 PM
  #11249
JayBee's Avatar
Post Re: Re: Pro 4, Hard to Set-up?
Hey pitshop, long-time no hear from. I'm sure glad that trade didn't happen. I still got my 'UNTOUCHED' SDW, trying out the Pro 4 I just got and getting the BD next week. Patience does pay off ... -JB
JayBee is offline
Old 05-13-2005, 04:13 PM
  #11250
JayBee's Avatar
DITTO... and where is everyone else finding their TIR ones? -JB
JayBee is offline
