Like Tree86Likes
Hpi Pro 4
Old 02-13-2005, 12:27 AM
  #10066
TRF Drive Hard's Avatar
Well if youre a tower member you can get 30 dollars off on a 200+ dollar order... ultimately youre only paying 259... not bad with the free shipping...
TRF Drive Hard is offline
Old 02-13-2005, 02:56 AM
  #10067
murfy's Avatar
Trader Rating: 9 (92%+)
speed tech is good n cheap. i think they have the 1.1 pro4 but i'm not sure. it's US$277.99 but shipping to aus is the killer.
murfy is offline
Old 02-13-2005, 04:54 AM
  #10068
VenomWorldOrder's Avatar
Originally posted by robk
the asphalt track had so much grip the arms broke!!
MAN! that is one insanely high-bite track!
VenomWorldOrder is offline
Old 02-13-2005, 11:04 AM
  #10069
pro4racer's Avatar
hi
i keep gettin through CVD bones all the time coz i keep rip-ping the pin straight through the holes i was told to not make my steering as a aggressive how do i do this .
thanks
pro4racer is offline
Old 02-13-2005, 11:39 AM
  #10070
Two choices.
1: turn down down your EPA to put less excessive load on the CVD.
2: Buy some steel UJ's and leave it the same.
You may have to adjust your setup to compensate for the loss of steering travel when you turn down the steering travel.
Jonathan
jonny69 is offline
Old 02-13-2005, 02:08 PM
  #10071
any good pro4 set-ups comming out of the snowbirds? and what are the best over-all pivot support spacers to use. 2mm......1mm...1.5mm...1/16"? thanx.
nomaak is offline
Old 02-13-2005, 06:32 PM
  #10072
S15Racer's Avatar
Originally posted by TRF Drive Hard
So does the track size determine what size pinion should be used along with type of motor? From what im trying to understand, it seem on a larger track, you can go large on the pinion size... but say if i use a 38t pinion on a short track, i can burn out my motor ya?
yes to all of the above
S15Racer is offline
Old 02-14-2005, 08:29 AM
  #10073
Guo Chean's Avatar
Hey kingcrab,
so how was the straight carbon chassis? does it work well? how much you plan to sell? please let us know. thanks
Guo Chean is offline
Old 02-14-2005, 10:25 AM
  #10074
Guo Chean : I'll test it at TITC 2005 this weekend. 3 world champion (Hara, Surikarn, Rheinard) join this race. I may ask Hara about setting. Then I'll let you know how it works.
I plan to sell 200 usd for chassis + upperdeck.
Kingcrab is offline
Old 02-14-2005, 11:03 AM
  #10075
scoobydo's Avatar
TWO BILLS!
scoobydo is offline
Old 02-14-2005, 11:32 AM
  #10076
I have noticed that there is a lot of play in the wheel axles.
This after running only 30 batts. Most cars have some play but not as much as on my Pro4. Anyone noticed this on their Pro4?
Is it the bearings or the MIP wheel axles?
moonman is offline
Old 02-14-2005, 12:47 PM
  #10077
Trader Rating: 42 (100%+)
I've been running my Pro4 longer then that with no problems as you described.
Does anyone know a site to buy the new HPI Aluminum Upper Camber link mounts or the Jet Racing Upper Inner Chamber Link Mount ?
Other then overseas sites...looking for something here in the U.S.
Nexus is offline
Old 02-14-2005, 12:52 PM
  #10078
dizzy1's Avatar
Trader Rating: 29 (100%+)
There seems to be a little more play than other touring cars in the front and rear hubs, but nothing to worry about.
dizzy1 is offline
Old 02-14-2005, 02:17 PM
  #10079
Guo Chean's Avatar
scoobydo : are you sure? that pretty expensive man how come cost so high? for the straight carbon chassis and upper deck?
Old 02-14-2005, 02:19 PM
  #10080
Guo Chean's Avatar
Sorry my message is for KingCrab
