Hpi Pro 4
#8131
The Evicerator
Erik,
How should you gear your car if you are running it with a battery strap?
#8132
polished wooden floor? Man that would be like a drifiting session or something. I would suggest you run the car very soft. But im just guessing.
Cheers,
Mossie
Cheers,
Mossie
#8133
Will Kimbrough spurs work on this car?
I want to change it but my LHS doesn't have any HPI spurs...
#8134
Yeah they will, but Yokomo spurs are the best. Jonathan.
#8136
Originally posted by CypressMidWest
I believe that when running a battery strap you should gear approximately 4 teeth higher than when taping your batteries.
#8137
oh geez
#8138
The Evicerator
Is that 4 teeth higher per inch of tape used...?
#8139
yup
#8140
#8141
Originally posted by Erik Shauver
That's a ridiculous statement, both HPI and Yokomo both use the same brand spurs... Xenon.
#8142
RC Driver Gary: I couldn't make it this year. Try afternoon… my morning is pretty full today.
All: as for strapping tape, you can't go wrong with 3M brand, 898 High Performance Filament Tape (Part no. 7686A12 at McMaster Carr )
Also, note the error in the instruction manual for the battery strap (see picture). Do NOT use the plastic spacers. Also, tighten the posts down as far as possible. In addition you can add the remaineder of the adhesive backed foam to the bottom side of the battery brace (you did cut foam and put in on the posts right????). Correctly installed, your batteries will stay put (AS I have personally tested )
-E
-E
I too have had alot issues with the packs poping out during a race, which is rather frustrating. Is there anyway you could post a pic of your battery slots to ensure that mine look up to par. I have tried a bunch of stuff to fix the issue, but nothing has worked so far and I might need to switch over to tape.
Thanks,
Art
#8143
y do u gear 4 teeth higher when using tape not a battery strap
its not changing the gear ration is it wots the point
#8144
Here is my current car (uses tape). It is how I would usually do the slots though. I take more off the edge that will contact the outer diameter of the cell. I only just "break" the edge that touches the side of the cell so it won't cut the cell's shrink wrap.
Note: the lower you can get the cell, the better off you'll be, but the trade off point is when you start dragging cells.
