Like Tree86Likes
Hpi Pro 4
Old 04-02-2004, 11:04 PM
  #3076
RCGaryK's Avatar
I dunno, you think a TC3 would have a closer setup then the Evo 3? I have Rod's setup from last year, along with TTLocal setup from some of the guys there too.
RCGaryK is offline
Old 04-02-2004, 11:39 PM
  #3077
RCTech Member #2
TSR6's Avatar
Gary, I have a diff I can tighten & lockl, and go to this parking lot you speaketh of, and we can both try different adjustments, then you'd haev some notes whjen you go to the Reedy. You'd probably have to give me a ride though, I saw the place last time i drove back up here
lemme know
TSR6 is offline
Old 04-03-2004, 03:29 AM
  #3078
chr15tophe's Avatar
Default steves vid
gr8 idea videoin your driving and car, makes it easier to see whats going on and what to change, rear end a bit loose there...
chr15tophe is offline
Old 04-03-2004, 04:51 AM
  #3079
tc3 racer sc's Avatar
Originally posted by TSR6
Well, I just got back from Trackside. I had the points lead wrapped up last week, but ended up extending it this week.
Just an idea until Team PRP finishes the gear brace: I put washers between the screw and the one way gear two races ago. I noticed that the screws were ended up leaving indents on the one-way gears, and the washers should help to spread the load from the screw to a wider area. I haven't roasted the one-way gear since then, so it may be to early to tell if it works, so far so good though.
TC3 - Please tell me you are using a quality tool set, and not the L-wrenches?!
Steve - on my first chassis, I used Losi thin tire glue. I ran a bead across the chassis, and smoothed it out with my finger. I don't really suggest this, but it works. After doing the whole chassis, I had a layer of glue thick enough on my finger that a few seconds under hot water, I was able to peal it off.
I used a thing called the "Microbrush" on the second chassis. Although I went through about 3-4 of the brushes, it was a little less messy on the fingers.
AJ's Raceway rocks as far as the surface and the barrier goes. I don't think it's possible to break ANYTHING on that track. It really is glass smooth, but I would suggest at least talking to the race director before you run. I don't know how they run the electric races, but when I went down there for nitro, I was told conflicting stories from the owner/race director on how qualifying is run. ( I asked if it was IFMAR, he said yes. Later, he told me it was a qualifying race, but your on your own clock. I asked if it was alright to start a little behind the guys to have a clean track with all the banging that was going on. He told me I better not, because it's a qualifying race. I asked again if it was IFMAR, and we were on our own clock, and he said yes. )
yes im using quality tools i hve good tools thxs for info
tc3 racer sc is offline
Old 04-03-2004, 07:30 AM
  #3080
Superfly1967's Avatar
Default Dog Tracking
Can anybody give me any tips on how to eliminate the dog track effect my Pro 4 has. The front end points to the left and the rear points to the right when standing behind it while running. Any help would be greatly appreciated.
It didn't seem to do this the first time out, why would it develop over time?
Superfly1967 is offline
Old 04-03-2004, 07:42 AM
  #3081
Super Steve's Avatar
Here is the damage...
I am gonna take the broken stud out and CA the knuckle... hopfully it will hold together!
Thanks for the comments on the video guys...
Super Steve is offline
Old 04-03-2004, 07:47 AM
  #3082
o ya, YEsterday's testing i had the bat strap and used the foam bumper space under the strap. I made sure the battery was in there tight but it can sliding out a little so i went to tape...
You sure that fukuyama battery strap will hold the batt in there tight?
my p2k2 got SUPER hot during those movies...
Old 04-03-2004, 09:22 AM
  #3083
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Yup...tested it last week, and will test some more today....off to the track i go
RCBuddha is offline
Old 04-03-2004, 09:57 AM
  #3084
Oasis's Avatar
Trader Rating: 38 (100%+)
Allways test with a body on the car(unless your setting the trims )that little bit of lexan helps..
Oasis is offline
Old 04-03-2004, 01:15 PM
  #3085
found out thgat my cvd bone on that side is fudgered up...
Old 04-03-2004, 01:22 PM
  #3086
Everything is cool. My Jr Crewchief (7 year old son that was trying to help) got his grubby little hands on the correct piece and had taken it to his room when it was bedtime.
Car is built and ready to rock. I have to say this is the best sedan I have ever built!!!!!! The quality is spot on as is the design. I cannot wait to hit the track tomorrow. Thanks HPI for giving racers a reason to come back!!!! The original RS4 with gearbox and all is where I got my sedan start, up through all the evolutions till the Pro2. Its nice to be back to smooooooth shocks again!!
Good luck to all on their racing ventures this weekend!
Doug Gaut is offline
Old 04-03-2004, 02:49 PM
  #3087
Anybody have any comments and help on this?
Old 04-03-2004, 03:00 PM
  #3088
Default Re: Dog Tracking
make sure all the Toe-in and Camber is equal. hope this helps.
True R/C Racing is offline
  #3089
Go over, Suspension, Droop, Any Binding in drivetrain too.
Old 04-03-2004, 03:10 PM
  #3090
Michal101's Avatar
Hi,
What pivot blocks and size sway bars come with the Pro 4 kit?
Thanks, Mike
Michal101 is offline
