Like Tree86Likes
Hpi Pro 4
Old 03-18-2004, 05:12 AM
  #2476
Frank McKinney's Avatar
I hope that you meant that sarcastically!
Frank McKinney is offline
Old 03-18-2004, 06:36 AM
  #2477
Super Steve's Avatar
Originally posted by popsracer
Associated Chassis Protector Tape.
Been several years since I've bought some, but any well stocked shop should carry it.
Rod, See you at the track.
How thick are these tapes?
Super Steve is offline
Old 03-18-2004, 06:59 AM
  #2478
OSherman's Avatar
Originally posted by Frank McKinney
The surest test (apart from Erik saying yeah they fit) is - do they fit?
c'mon ... that would be too easy...
actually, my stash isn't just a PRO3 stash... could mistaken a different cars axle for a PRO3 axle.
OSherman is offline
Old 03-18-2004, 07:02 AM
  #2479
OSherman's Avatar
just imagine a flexible piece of lexan with adhesive backing... about as thick as most lexan bodies... good stuff..
OSherman is offline
Old 03-18-2004, 08:29 AM
  #2480
popsracer's Avatar
Default Which Hex Hubs??
Guys;
I was noting in the Pro4 Manual that it shows 1.5mm of spacers being used over the Wheel Hexes. This I do not like, as my favorite wheel is Yokomo and they already have very shallow Hexes.
Who makes a direct fit Hex Hub that is longer? (Buy HPI is out) I like the clamping Hubs better than the O-ring kind.
Thanks,
Steven
popsracer is offline
Old 03-18-2004, 08:32 AM
  #2481
rc-zombies's Avatar
Default Re: Which Hex Hubs??
Guys;
Thanks,
Steven
Steven
I don't like it too... I posted a link to the Integy/Atlas clamping 6.2mm hex hubs a while back.....and in Purple! the HPI wider hex is 6.3mm
rc-zombies is offline
Old 03-18-2004, 08:39 AM
  #2482
Hmm...
would this make your car's bottom go less shiny after you move it?
because of vibration against the carbon fiber plate from the lexan...
my pro 2 made underside of my servo go all rough and the carbon fiber "clear coat"? kinda disapeared
Old 03-18-2004, 08:48 AM
  #2483
David Joor's Avatar
Hmm...
It is adhesive on one side, no vibration.
David Joor is offline
Old 03-18-2004, 08:50 AM
  #2484
rc-zombies's Avatar
Hmm...
it would still be like new..... there is no vibration...it's not really lexan..more like a very think vinyl. it's self enhesive and not moving anywhere
if it does get dull.... a little automotive clear-coat polish will make it shiney again....
Old 03-18-2004, 08:54 AM
  #2485
Erik Shauver's Avatar
Erik Shauver is offline
Old 03-18-2004, 09:07 AM
  #2486
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Guys;
Thanks,
Steven
Pops,
The yokomo wheels fit fine with the spacers, that's how I've been running the car @ socal. If you can't wait for HPI, Tamiya's clamping hub set for the TA04 should fit, and its a lot thicker. SoCal had some blue ones in stock on tuesday, last I checked.
Buddha
RCBuddha is offline
Old 03-18-2004, 09:43 AM
  #2487
rc-zombies's Avatar
Originally posted by Erik Shauver
rc-zombies: Nice work on the plate!
hope it survives the battle this weekend...
Is HPI coming out with a reinforce bevel gear of some kind? graphite plate?
Old 03-18-2004, 10:40 AM
  #2488
David Joor's Avatar
Erik - you can't expect us web guys to have a clue, come on! j/k Frank.
Old 03-18-2004, 11:32 AM
  #2489
rayhuang's Avatar
Going to practice tonight and sitting on the wall is a shiny new box with Pro4 on it!!! hahaha! Ohhh-so tempting!!
j/k-after the Nats for sure!!
rayhuang is offline
Old 03-18-2004, 11:42 AM
  #2490
CypressMidWest's Avatar
You have another 4 to worry about right now!!!
CypressMidWest is offline
