Hpi Pro 4
#1696
Protus - just curious, did you do the hot water trick to the gears?
#1697
Re: TRANSPONDER HOLDER/SERVO SAVER
Originally posted by rc-zombies
A couple of new option parts released by Jet Hobbies
Transponder holder/servo mount, servo saver linkage.
Pro4 decals now available too....
woo hoo! Thanks for the update!
#1699
Frront diff gears
I too was a victom of broken front diff gears on the one way. I DID NOT boil them. The next set will be boiled. And a diff installed. I have a second kit for parts on the way.
For the first time out....WOW!!! I was running foam on carpet. From the kit setup(which is a rubber tire setup) All I changed was to location of the rear shock, to the most inside hole. And droop, 2mm. The car is to soft with the gold and silver springs, but very balanced. I'll have a new setup next week.
-Derek
-Derek
#1700
Unfortunately I didn't boil the gears. It didn't even cross my mind since I didn't do it to the TC3 or the NTC3. Oh well! I'm thinking about picking up a second kit for spares, as well as a back-up car.
One other thing of interest, until the new pivot blocks come out, I'm thinking about running the XXXS rear hubs and axle on the Pro 4 to take some toe out. I'll work on it tonight and let you know how it goes.
Jeff
Jeff
#1701
Re: Frront diff gears
-Derek
-Derek
The one thing that does puzzle me is how much the car rolls. It seems that with everything placed centrally along the axis of the car that there would not be enough leverage/force to cause the chassis to roll, UNLESS the CG was pretty high. But looking at the car the CG does not look that high at all. Dang, I've got so many different things that I want to try on this car. I hope everybody's first time out with this car is just as good as mine or better. Good luck to all
Jeff
#1702
Jeff
Jeff
Still VERY happy with the car.
#1703
R/C Tech Elite Member
Re: Chassis Roll
Glad to hear it did well on carpet with foams. It didn't surprise me that the stock setup would be too soft.
Jeff
Jeff
In regards to the rear toe: has anyone tried switching the 3.0 degree mount to the front, and putting the 2.5 to the rear? That may help until the new mounts make their way into the hobby shops.
So can I assume that TC3 springs fit the shocks with no problems?
Buddha
#1704
Yes, TC3 springs will work
#1705
i evntually be getting one i just met one of my dads freinds who works at hpi im gonna see if he can hook me up with it or ill just get from work
anything i should do while i build it
#1706
Originally posted by RCBuddha
Proteus,
Did you boil the gears b/f you ran the car? The racing @ SoCal last night looked like "bang up derby", i don't think many were getting through traffic very cleanly (at least, from what I saw). Was Slim calling traffic for the leaders??
Buddha
Proteus,
Buddha
#1707
Has anyone broke the front diff gears that has treated them?
#1708
Not yet, i got spare gears and diff's but have'nt needed them yet.
#1709
Hey Guys
What are the necessary spare parts and hop-ups for the Pro 4, I not wanting to spend to much money
WADE
WADE
#1710
Shortyzz,
Titanium Screw set would be a great start and that's about it, it's a fantastic kit out of the box!!
