Like Tree86Likes
Hpi Pro 4
Old 04-17-2013, 05:23 AM
  #15751
Trader Rating: 54 (100%+)
Originally Posted by OVA
Are you sure..I thought the TC4 is standard bearing and the Pro4 is metric...
im about %90 sure it doesnt fit LOL ....the only gear diff i think you might be able to fit is the team c t4 4wd buggy
rkhess is offline
Old 04-17-2013, 07:14 AM
  #15752
Oasis's Avatar
Trader Rating: 38 (100%+)
Ok..don't believe me....the gears fit for a fact, you have to use both ring & pinion though..
Oasis is offline
Old 04-17-2013, 08:19 AM
  #15753
I have some unused spools sitting in a box. And I believe there is a oneway in there as well.
ATXPro4 is offline
Old 04-17-2013, 09:40 AM
  #15754
MikeR's Avatar
Trader Rating: 15 (100%+)
Just an FYI the associated tc4/b44 diffs work in a pro4
You said the diff fits- that's about $20 difference in parts between a diff and a diff gear.
MikeR is offline
Old 04-17-2013, 05:03 PM
  #15755
Oasis's Avatar
It's been a while but I did run the tc4 diffs in my pro4, I was using the same diffs out of the ntc3 also..I'm trying to remember what we were doing to make them fit..but they did..I don't really care if you believe or not..but guess you never noticed the similarities between the tc3 & the pro4? You know you can use the cvd shafts from a tc4 also right..
Oasis is offline
Old 04-17-2013, 06:20 PM
  #15756
beemerfan's Avatar
Trader Rating: 39 (100%+)
Just stumbled on this conversation so I thought I'd chime in. I have several TC3s and I've also had a couple of HPI RS4 MTs. The heavy duty one-way for the TC3 uses a different bearing than the standard one. I think the bearing is metric because the same ones fit on my RS4 MT one-way. I think the inside diameter is different on the bearing but the outside diameter of 5/8ths is close enough to 16mm to make it work. So the TC3/4 diff should work if you also use the bearings.
beemerfan is offline
Old 04-19-2013, 05:12 AM
  #15757
theproffesor's Avatar
Trader Rating: 66 (100%+)
All right does anyone that subscribes to his thread have one they want to sell
theproffesor is offline
Old 04-21-2013, 07:35 PM
  #15758
PAPOSWING's Avatar
Trader Rating: 18 (100%+)
Originally Posted by akimoto
I have 3 of this cars , all for sale, tons of parts....
Marius
What up Marius, I need parts 4 my pro 4.. check pm ..
PAPOSWING is offline
Old 04-21-2013, 09:40 PM
  #15759
Marius
I've been looking for this car. If you still have one or all for sale. I'll take them off your hands. Please email me the price and where to send the payment. [email protected]
Juan Aveytia is offline
Old 04-22-2013, 12:40 AM
  #15760
MikeR's Avatar
The Ol' Pro4 still has it! Winter trophy race a few months ago. Announcer rubbing it in about the oldest car on track at the 4min mark
Red and black car= Pro4, 13.5 blinky expert A main.
+ YouTube Video
MikeR is offline
Old 04-29-2013, 04:23 PM
  #15761
Ok so... I got the T.O.P. light weight diff parts in the mail yesterday and if I turn down the outer diamiter of the diff it will fit in the ring gear. The screw holes in the case align perfect with holes for the diff balls. Now if I could just find a whole diff with outdrives and not just the rebuild kit.
Old 05-05-2013, 09:27 AM
  #15762
Well going back to the ball diff, to much work to get the T.O.P. diff to fit. It wouldn't be difficult if had access to a lathe, but I am not going to attempt to turn down the outer diameter evenly with a dremel tool. I am just going to drop some cash on some TLR tungsten diff and trust balls, they are the same size as the pro4 stuff.
Also still looking for another one of these to put on the track, PM me if you have one
Old 05-08-2013, 03:33 PM
  #15763
I have 2 chassis for sale, 1 brand new, the other used
if your interested look it up in the for sale forum
Old 05-12-2013, 04:27 AM
  #15764
idbdoug's Avatar
Trader Rating: 41 (100%+)
Hello
I have a friend with the pro4. He is trying to run the car in VTA. We r having a problem with the rear end breaking loose in the corners, wether its on power or off power. I'm familiar with TC's but we can't seem to find a setup to keep this from happening.
Does anybody have a good setup for VTA? I've reached wits end trying to figure out how to keep backend planted!!
idbdoug
idbdoug is offline
Old 05-12-2013, 06:05 AM
  #15765
I am running my pro 4 in.VTA and its great. Suspension is 30wt silver spring rear 35 gold spring front. rear mounting is middle middle front is middle inner. inner supsension blocks are raised 2mm all theway around. 4deg caster blocks 3 deg rear toe. inner hole on front and rear camber mounts. ball studs raised 1.5mm. rear hub camber mount out hole no washers. I run on outdoor concrete. If your buddy gets too fed up with it I will take it off his hands. possible trade with TCX with spec r diffs front and rear.
