Like Tree87Likes
Hpi Pro 4
Old 07-31-2010, 06:50 AM
  #15676
Pablo Diablo's Avatar
Yep. You can run diffs and spools both front and rear.
Pablo Diablo is offline
Old 07-31-2010, 10:36 AM
  #15677
Deebs's Avatar
Is there an upgrade for the cvd assembly or bone?
I am now running the spool and I keep going thru cvd assembly
Deebs is offline
Old 07-31-2010, 11:21 AM
  #15678
Oasis's Avatar
Trader Rating: 38 (100%+)
These don't last much longer but they are waaaay cheaper ($7 for a pair)..Associated TC4 carbon CVD's and use the stock Pro4 axels..I've never broken a set.
Oasis is offline
Old 08-02-2010, 08:54 PM
  #15679
sliding_josh's Avatar
Trader Rating: 21 (92%+)
Hello guys im a new guy here!
My son drifts a belt driven HPI what diffs should he use for Drifting?
LMK thanks!
sliding_josh is offline
Old 08-23-2010, 08:29 PM
  #15680
Default Help on Pro4 FDR for 11.5t brushless
Hi Guys...
Need some help on the best fdr for Pro4...
Can you guys give me some information what will be the best fdr when i'm using 11.5t brushless motor?
Small track?
Med Track?
Big Track?
tq guys
k4mp4q is offline
Old 09-19-2010, 12:23 AM
  #15681
TeamWTF's Avatar
Top Photon driveshafts fit.... would be best to mill out the spool to use the plastic blades... which is what i will do next time i need to replace the aluminium CVD's
Oh, and just want to say how much i STILL love this car... bought it new WAY back in the day and still love it just ordered some new hubs and rod ends to freshen it up a bit...
TeamWTF is offline
Old 09-19-2010, 06:29 AM
  #15682
mangoman's Avatar
Ive been wondering for a while if the car handles better these days (relative to belt drive cars) now that that minimum weights are lower?
Although i think being competitive without a spool up front would be tough. As a spool will just smash up the bevel gears
mangoman is offline
Old 09-19-2010, 08:01 PM
  #15683
TeamWTF's Avatar
I have been running the spool in it with 17.5 and its fine. Will be running it with 10.5 shortly... The bevel gears are fine if they are meshed correctly and you stay off the barriers. And yes, its great with the new weight... I have heard that the cyclone 's' arms work great on the Pro4 to add overall traction... and comments?
TeamWTF is offline
Old 09-19-2010, 09:23 PM
  #15684
mangoman's Avatar
To tell you the truth i havent run tourer in a while but i was rebuilding my pro 4 not long ago.
Unfortunately for me keeping off the barriers and such isnt exactly a viable option, but i was thinking about putting a slipper spool in the front.
Yeah the cyclone s had the high traction arms included in the kit, which were a softer material. Its a cyclone part, 31420 should be the part number you want.
Just make sure if you get some you label them as they look identical to the standard arms.
mangoman is offline
Old 09-19-2010, 09:26 PM
  #15685
Oasis's Avatar
I always liked a oneway more than a spool..but they both have their place and track..the best "thing" for traction for a pro4 is the 2mm chassis, then tune with the different top decks....Hara ran a 2mm chassis on his pro4 and used the different top decks to change the traction handling. Stock for a pro4 is 2.5.
Oasis is offline
Old 09-19-2010, 10:45 PM
  #15686
TeamWTF's Avatar
Interesting... Was thinking about a thinner deck.... having some trouble keeping the speed through the corners.
TeamWTF is offline
Old 09-19-2010, 11:07 PM
  #15687
Oasis's Avatar
Why would a thinner chassis lose speed in the corners? I don't think that you would lose speed, remember you can make the chassis stiffer by changing the top decks, they did make a 3mm top deck.
Oasis is offline
Old 09-19-2010, 11:44 PM
  #15688
TeamWTF's Avatar
no no... iam losing speed with std chassis... so i want to try the 2.0 chassis to see if it helps
TeamWTF is offline
Old 09-20-2010, 12:01 AM
  #15689
TeamWTF's Avatar
Might try and mill the standard chassis a little? Anyone tried this with this or other chassis?
TeamWTF is offline
Old 10-04-2010, 06:22 PM
  #15690
Looking for a driveshaft for a PRO 4.
tc3jp is offline
