FF'07 RC Concepts 12th Scale Kit
just been trawling 12th scale thread and there are some threads about the FF'07 but can't find much about setup's etc
So as a starter here's a link to all threads for the
FF'07 1/12th scale conversion kit on rctech 12th forum
lets discuss the car's progress in this thread
get posting those setups & pix
hey guys well i can tell you i have been racing this car for about a year now right after he started selling them. it is a sweet handling car! the web site for more info is www.ffrcconcepts.com he is in the middle of moving right now so if you e-mail him it might take him a few days to get back to you at this point!
all of our dealers can or do carry the FF07 conversion kits.
You can get some images here.
http://molzermoweryracing.com/product_news.htm
Some highlights.
tweak allows for preloading tplate, and changing the flex point on the t plate.
If you break a t plate less work to get teh car back to were it was.
Extremly low CG.
Batts have rom to move for and afdt in chassis to change handling.
Front bumper/chassis plate severs in sever impact replaing only screws is required not whole chassis plate.
Some highlights.
Extremly low CG.
very forgiving car if set up is not perfect, still easy to drive
FF07 setup @ TRCC
low grip carpet as no addy had been laid down for months
Front
spring #20
ride height 3.5mm
BRM purple foam @ 43mm
CS High Grip addy / full width
Toe in = 0 (small amount bump steer)
10 degree castor washer either side + carbon brace
Camber = set to run tyres square / no coning
Rear
AE shock / length = to set droop @ 1.5mm / Green spring / 30wt oil
0.063 T-Bar / screws just to say touching
Ride height = 3.5mm
BRM grey foam @ 46.5mm
Droop = 1.5mm
Damper Tubes = 100wt oil
T-Bar. 0.063"
standard tweak screws just touching, tuning fork screws not used
Electrics
MRT MX Pro
BRM 19T(Corally Black series based} / XXX brushes / 44 to 45mmpr
Team Almighty IB42’s @ 5amps
ran the batteries in the middle
Body
CEFX LMP900
Front
spring #20
ride height 3.5mm
Rear
Ride height = 3.5mm
Droop = 1.5mm
T-Bar. 0.063"
Electrics
MRT MX Pro
Body
CEFX LMP900
Insn' that Jaris car??
Will somebody be at the IIC?
no, it's mine
just took the pic this morning
Guys,
Thanks for opening new thread for FF’07. There are many cars out there and feedback is been positive. Thanks for all those good words. Let’s keep questions and setup info rolling here and try making car even faster.
I’m middle of move at the moment. New “headquarters” location is in Connecticut. This move wasn’t in my radar last spring so it comes from blue sky. I will have plenty of spares in stock and a few kits right now. Kits are available thru Molzermoweryracing so all hobby shops can get kits/spares thru them.
I’m not be in Vegas this year but Gate Halloween race and Cleveland indoor champs are in my calendar so we will see there.
Jari
Jari
MMR will have a FF07 at vegas though. check it out with the S400's.
FF07's TQ and go 1, 2, 3 at LSRCC Dec 2nd race.
