The One True 13.5 Thread >
Old 09-06-2007, 05:11 AM
  #31
Joel Lagace's Avatar
Great thread, kinda takes over where my thread went bad about ROAR STOCK BRUSHLESS..
I really hope ROAR steps up and comes up with next generation 27T and 19T stock rules. Currently or for the last few years or decades in the case of 27T these classes have been very successfull. Im really hoping that we see a standard or rules capping the cost and performance out put of 13.5 and 10.5
I know each club can do what it wants, but without some sort of leash or rules there could easily be the motor of the month wars with the next 13.5 pushing the limits are really out performing the older 13.5. Just with in the novak camp there is 3 13.5 motors all wich perform differently. I know brushed stock advanced with fast motors but it was all done within a set of rules to ensure a 27t did not become a 26t with 26degrees of timing..
Joel Lagace is offline
Old 09-06-2007, 06:33 AM
  #32
PitNamedGordie's Avatar
Originally Posted by maximebeauvais
now, why do we have to do all those testing...why ROAR don't do his job on brushless motor? it is because all the big motor tuner have too much influence on ROAR
Good point. ROAR will have to come around soon. With that said my local track allows 13.5's and Lipos...not sure that will change once ROAR comes up with something.
PitNamedGordie is offline
Old 09-06-2007, 07:21 AM
  #33
Trader Rating: 16 (94%+)
Good Point, but then we could start talking conspiracy theory like on all sorts of things.
From what I can tell, ROAR takes it time to see where the market is going so they can change their rules accordingly instead of trying to make rules to drive what the market can do. They don't have the power to regulate RC, only create rules that allow somewhat fair competition based on market direction. In this case, Brushless is still in its infancy, although Novak has been in Brushless for 4-years now. Only in this year (2007) has everyone else decided to jump into Brushless. I would expect 2008 or 2009 to fully encompass Brushless, but I think Lipo batteries are still a few more years away.
kn7671 is offline
Old 09-06-2007, 07:33 AM
  #34
ehlert's Avatar
Trader Rating: 30 (100%+)
brushless rocks, i have raced the summer sizzler and the vegas warm up race and did not need to cut my motor or put new brushes in
ehlert is online now
Old 09-06-2007, 08:20 AM
  #35
Isn't that wonderful, no motor maintenance.... Why can't all the brushed guys get that through their head.
Anyway, I would be interested to see someone test each 13.5 Brushless motor and compare lap times, or compare power outputs on a dyno. Hopefully they are all close, no specific advantage to one.
kn7671 is offline
Old 09-06-2007, 08:39 AM
  #36
Does anybody know what motors are equal to the Novak SS13.5 pro? LRP? Orion? Etc.... I am trying to compile a list we can present to our club to limit the motor of the month thing...
Anyone know anything on the LRP Eraser??? And how does the LRP Vector 13.5 compare to the Novak ss13.5 pro? Does the Vector have adjustable timing?
I am also trying to find some specs on the Tekin 13.5 motor that is due for release at the end of the month... I have e-mailed the tech department and have received no reply...
JPG333 is offline
Old 09-06-2007, 08:46 AM
  #37
TimPotter's Avatar
Trader Rating: 15 (100%+)
Joel,
I have had some discussion with EXCOMM members about stock/19t brushless rules, and in passing was told that a group of manufacturers, along with ROAR, is working to come up with a better set of rules to govern these type of motors.
TimPotter is offline
Old 09-06-2007, 10:16 AM
  #38
GreaseMonkey's Avatar
I can only go by my experience but in the past 3 weeks I have run a Novak SS13.5 and an LRP Vector 13.5 (bonded rotor) and for me, the lap times are extremely close (Fastest lap with both is 9.6). On a personal level, the LRP felt stronger coming out of the corners but that didn't result in faster lap times.
GreaseMonkey is offline
Old 09-06-2007, 10:32 AM
  #39
so in your opinion would a LRP run better on a technical course?
jsl6v8 is offline
Old 09-06-2007, 11:02 AM
  #40
razzor's Avatar
I guess you could say that guys would use the "Feel" to suite there driving styles but from what ive heard there should be similarities in Kv and RPM between 13.5 spec motors.
Some might be torquey and some less just like brushed.
I might be wrong but its what ive been picking up from reading the board.
razzor is offline
Old 09-06-2007, 11:46 AM
  #41
rc-zombies's Avatar
Originally Posted by Hebiki
kinda wish the other two "copied" the Novak design with the solder tabs
these are available from SpeedPassion
to work with the LRP or Orion open type solder holes
rc-zombies is offline
Old 09-06-2007, 12:26 PM
  #42
Default Tekin 13.5 brushless????
Does anybody know any inside info on the Tekin 13.5 motor coming out? I have tried to get Specs from their technical dept. and not a reply. Their website is also lacking information. Normally I wouldn't care, because they are a small company... But we have a few guys that are intrested in it up here and I want some facts on it before we allow it.
And the other question I have is will the Tekin 13.5 be faster than the Novak 13.5 because it is unsensored???
JPG333 is offline
Old 09-06-2007, 12:29 PM
  #43
Ha, those look just like those peg things for your cheap furniture adjustable height shelving.
kn7671 is offline
Old 09-06-2007, 12:35 PM
  #44
Soldering the wires direct to the motor would be a better connection if you know what you are doing. Every time you solder something into a circuit it creates resistance.
JPG333 is offline
Old 09-06-2007, 12:38 PM
  #45
rmdhawaii's Avatar
Can you say, "Handout 13.5 BL motor?"
I'm just kidding. With multiple manufacturers involved, there is always going to be a slight difference in performance between stock motors - and as has been mentioned, there will always be the newer and better BL motor within the manufacturer's own product line. I think the words, "You just can't win", come to mind. Short of ROAR coming up with a build spec (Wouldn't that be something!), all motors will not be created 100% equal.
BTW... Is it just me or would you guys also like to see ESC, profile and track info (surface/size/layout) when people talk about motor performance and comparisons? IMO, it makes a difference.
rmdhawaii is offline
