EP4200's
#124
MCSmooth is visiting every lipo thread I've been too lol. Damn, this dude is a stalker.
#125
Give it a rest. Your whole point to this thread was to further your own LiPo agenda, and everyone can see that.
#126
Um, no jackass. It was in response to another thread where I inquired about lipos that were not made by Kokam. They were slammed for being sub-par lipos made in China. I thought that if lipos made in China were "so crappy" and looked down on, then why not sub c's??? Before you speak to me, get the facts and put an eye on your lips and WATCH YOUR MOUTH!
#128
There is no one in this room that was present to monitor what he did, when he did it to either substantiate or repudiate his charging methods, ergo, I take his word for it. What reason does he have to lie? Can he get a refund for his troubles from airing grievances in a public forum? Does he stand to gain by "tarnishing" the cell distributor? Will get brownie points for pointing out the finicky charging habits one must adhere to when charging 4200's? ...............My point, thank you.
First of all there was someone present when vic was charging. Brad spoke to this person and got the full story about the long lockout being used (on more than 1 pack).
Second...there is nothing finicky about an ep cell. Step 1 discharge.....step 2 charge it.....step 3 use it. Sounds pretty simple!!!
This was user error......there is nothing left to argue about.
#129
#130
Sub C Cells-Been making these for years for R/C use and they have plenty of experience with them.
4200's=The reason these cells are so testy is the resistance is lower than EVER and the cell discharge's itself at a rapid pace. Care for them the right way and this wont happen. Hobbyshops need to TRAIN their people to explain these batteries more or have a print out made for each customer.
IB4200 experience-Build the pack,discharge it to .9 and then charge it the 1st time at 3-4 amps.Run it with a stock motor and be kind of easy on it.Your taking 6 cells that have NEVER been together and forcing them to be friends in a weird way.Let them get use to each other.
I charge them the 1st time at 3 amps,2nd time at 4,3rd time at 5 and then by the 4th charge im at 6 amps and keep it at 6 after this.
DO NOT USE A FAN WHILE CHARGING OR DISCHARGING 4200's.BIG NO NO!!!!! I have had about 60-70 packs of high quality 4200's with no issue's following this process.
Lipo's-Biggest problem here is the consumers trying to CUT CORNERS like they always do.They will buy a 7.4 volt Lipo that is 10C,12C,or 15C rated which is not good enough for most of R/C CAR applications.They need to be 20C,25C rated to be used in R/C Cars.
People will find these cheap packs on ebay and try running them with ONLY problems occuring.
Now on reciever packs you can use the LOWER C rated packs but not to replace battery packs.
Plus alot of companies have years of experience with SUB C's and just a year or 2 with lipo's. They have to learn from mishaps and they are still learning.
I like both batteries and LOVE my IB4200's.When cared for they work great with NO grief whatsoever.
Les
#131
You came in late, posting that stupid ish, and got at me. I took it personal because I started this thread and asked folks not to flame and refrain from personal attacks. You pissed me off with your "Johny come lately" placard, so I got at you. You read enough threads and saw some of my posts, it could get worse. Take it and run with it.
#134
to josh
This person that was present may have thought that it was all packs but i did mah to one pack and only one. two let agian a whole team has to be involed to make one person quite. why is this. to dave we both know that mah was done on only one pack because the secound time it was used on that pack was after i had ran it and the discharge and eq and then did mah on that pack. brad are you going to come out and say how you treated me on the phone or not.
