WHAT does this part do
I have a road runner Xpress and i got some spare parts in a little box. One that caught my eye was a FRONT BELT BEARING IDLER
Where would something like this be fitted on the car
The thread with the pics of the car is http://www.radiocontrolzone.com/foru...t=mystery+part
Thankx
Thankx
Re: WHAT does this part do
Thankx
Thankx
Thankx Howard. if anyone knows about this part feel free to post
If I remember right it's basicly a front belt tentioner I thing it goes somewhere on the chassis just in front of the bateries but behind the servo.
Thankx SEE. If you could look at the pics iv posed on another forum could you point it out for me
THANKX
THANKX
ok i tried to mount it but no luck. i had to stretch the belt so much that im scared i might brake it. When that belt tensioner is in the belt looks like this. It is VERY TIGHT. HELP!!!!!!!!!!!!!!!
Motor---------/- \ ------------ servo
anybody!
tl01 1989;
Again, send a PM to mb-racer if you need help. He's the MAN.
Also your belt should NOT be tight, loose without skipping or rubbing on the chassis is the correct tension.
Thankx for all that replied . I sent a pm to mbracer so im in good hands
The part in question mounts on the left side of the top deck about in the middle. It used to keep a little tension on the middle belt. There are several Xpress PROs around here and we just do not use this part. We feel that it is unecessary and we have had no problems running the car without this part.
Hope this helps.
Hope this helps.
yes that helps a lot. I guess thats why its not there on my car right now.
CHAMP: any other tips and info you could share on this car would be appreciated
correction: CRASH
