GTB and the little lights
When setting the drag brake on the GTB if you make a change the instructions indicate that when drag brake is used the BLUE led will stay on along with the RED in normal operation. I disabled the drag brake by setting it to the 1st setting which in turn disables the drag brake. Only the RED led is on in normal operation with this setting. I noticed that if I make changes in the Min Brake setting that it turns on the BLUE led along with the RED when it in normal setting. If the blue is on then that means the drag brake in enabled. I'm confused? I would think that if I disabled the drag brake then the BLUE led shouldn't show even if I make changes to the Min Brake settings. Is it me or the GTB?
Hello,
When you enable the Drag Brakes you get "red, Blue, Amber" on at neutral.
When you enable a Minimum Brake setting you get Red, Blue on at neutral.
If you turn off the drag brakes, (via setting #1) you should get just a red light.
So it sounds like everything is fine.
[email protected]. Email me if you need further assistance.
