TC3 64 pitch gears >
TC3 64 pitch gears
TC3 64 pitch gears
Old 11-14-2005, 07:52 AM
Default TC3 64 pitch gears
I'm thinking about changing over to a 64 pitch spur, what size gear should I start with?
rockdog200 is offline
Old 11-14-2005, 08:00 AM
96 tooth is a good place to start.
knapster is offline
Old 11-14-2005, 11:27 AM
100 will work also
THE DARKSIDE is offline
Old 11-14-2005, 11:58 AM
Big Rigg's Avatar
I drove a TC3 for 3 years, put on a 64 pitch gear one time.. ran 3 laps in practice, didn't hit anything and stripped the gear going down the straight... went right back to my pit put the 48 pitch back in and never looked back... yea the fine tuning of gear ratios is great and all, but how many races will you dnf beacuse of that stupid gear stripping? The ratios for 48 pitch will get you close enough to be highly competitive, IMO stick with the durability.
Big Rigg is offline
Old 11-14-2005, 01:50 PM
Anthony.L's Avatar
Trader Rating: 41 (100%+)
I'm running 64 pitch (along with everyone else at my local track) and have gone through some pretty good crashes and never stripped the gears. Normally stripped gears are due to not properly setting the spacing or loose motor bolts.
Anthony.L is offline
Old 11-14-2005, 03:16 PM
Super Moderator
Grizzbob's Avatar
Same here, been using 64 pitch for about 6-8 years on my touring cars(from Yokomos to a TC3 & now my FT TC4), & the only times I've ever stripped them is when I did a poor job setting the gear mesh. Granted, they do not offer the big edge in efficiency, but I like them for the adjustablility of ratios without changing the spur much. If you set them right, you WON'T have a stripping problem(but it DOES take some patience & practice to learn how to do it right every time)....
Grizzbob is offline
Old 11-14-2005, 07:09 PM
Ok I have never ran 64 pitch gears before so what is the best way to set the lash? I ran outdoor offroad for years with 48 pitch with no problems. This carpet racing is all new.
Old 11-14-2005, 08:41 PM
slippery49's Avatar
Default 64 pitch
i run a tc3 on asfalt and i run a 92 spur and a 47 pinion
slippery49 is offline
Old 11-15-2005, 11:37 AM
I have run the same 100T 64P spur on my TC3 for 2 seasons now. I run 64P gears because as an over racer, I already have a complete set of these gears and do not want to invest in a set of 48P's. I have even run 64P gears on a T3 off road truck without damaging the gear. I guess that if you are having problems, you need to learn how to better mesh your gears and tighten your motor screws. No matter what pitch of gear you run, If you do not mesh the gears correctly, you'll be having problems.
Old 11-15-2005, 11:49 AM
64P= $$$
runnin rc10 is offline
Old 11-19-2005, 04:49 PM
slippery49's Avatar
They Strip Easy
88 45 wil also work
Old 11-19-2005, 05:25 PM
Tornado_Racing's Avatar
Have you guys tried PRS 64 pitch Touring Car Gears. Because they are machined they spin perfectly round so you can run a much tighter gear mesh. This should help with reducing the "stripping" issues. If you mate the PRS 64 pitch Touring Car Gears with our 64 pitch Pinions, you will also have the lightest pinion/spur combo on the market.
Tornado_Racing is offline
Old 11-19-2005, 09:15 PM
koabich's Avatar
Dude,you cannot just say stuff like that...it's not true. If you stripeed a 64 pitch gear, you are not doing something right...either that or you were running defective gears. And I can hardly beleive that you will never use a 64 pitch gear based on 1 experience!
I ran 64 pitch in my TC3 for over three years. The only time I stripped a spur was when it was my fault. Not clamping the motor down tight enough or hitting something that would cause the cam to come loose allowing the motor to shift.
There's nothing wrong with 64 pitch.
koabich is offline
Old 11-19-2005, 09:23 PM
Tim Stamper's Avatar
I am still running a PRS 100tooth spur that I put on the car at least 5 months ago and I have run everything from stock rubber on asphalt and 19T foam on carpet with my TC3 and the spur is flawless. They hold up better than any other spur I have used over the years.
TS
Tim Stamper is offline
Old 11-19-2005, 09:31 PM
anthony390's Avatar
umm what are the standard 64 pitch gears for the tc3 and can i fit an 88t spur(64 Pitch)?
anthony390 is offline
