I have a little problam.
Hi i just finished putting my electronics in my T3. I took it out of my pan car. And i tried to run it and it ran great but when the car goes about 10 feet way it starts to glitch. The car goes slow and i think it might be the reciver. Do you think so? thanks.
Re: I have a little problam.
* Ensure the small capasitors are correctly mounted on the motor.
* Check wiring. Avoid motor/batt wires close to the RX and especially, ensure the arial are away from those electric noise sources.
* Check that the arial wire aint broken.
* Ensure the arial aint been cut shorter.
* Ensure there's enough voltage on the TX.
Wll i am going to reset the ESC and if that doesn't work i will try a doffrent radio and see if the reciver is busted.
make sure your transmittey batts are full
If it runs great then I'd leave it alone, I don't understand what you are saying when you say
I'm still confused. If everything worked fine in the pan car then there's nothing wrong with your peripherals.
maybe your plugs to the reciever are faulty.
I think is the ESC.
