How do you de-anodize aluminum
#31
In this case,,you don't need to bother with the oven cleaner since you will be polishing the coating off anyway..
And RiT dye works wonders for anodizing..
The comments on this topic aren't suggestions, they're tried & true procedures that were researched from various other sources.
#32
Clearances
One thing to be carefull of, removed some anodising can affect the clearances between parts e.g holes now become slightly larger and shaft become smaller and the play can be felt
#33
Only if the part you're dying never sees the sun. I have several parts on my MR2 that I anodized and the parts that saw sunlight stayed red for about 6 months before they faded.
My reason for anodizing wasn't to make things pretty though. I made caliper brackets for a set of 996C4 calipers and I wanted them anodized to protect against corrosion between dissimilar metals (aluminum bracket, iron hub). The dye was only used to make sure the part anodized properly.
As for stripping the anodized layer, a tablespoon of lye in about 32oz of water works really well. Swish it around and the color just washes right off.
#34
Anyone ever deanodize a brushless motor? My motors blue & the rest of my chassis is bare polished.
Figured I should take it apart, but what about the stator & bearings?
#35
The purple cleaner works good to strip aluminum and its not harsh like easy off.
