Integy Motor Sink fan >
Old 05-25-2007, 05:07 AM
Default Integy Motor Sink fan
Hey guys so i was looking into getting a heatsink fan for my motor, and i found this, http://www2.towerhobbies.com/cgi-bin...?&I=LXNPG0&P=7 ..its an integy.. However the connectors according to the website is a JST type connector, where would i plug that into? I'll be using a GTB if that matters.. also at the end of the month they'll have another one with BEC type connectors, would that be easier to set up? ie just plug into receiver i assume.. thanks!
dorick is offline
Old 05-25-2007, 05:10 AM
rcstunt101's Avatar
Trader Rating: 16 (100%+)
It can plug into the spare BAT channel in ur reciever. Otherwise u can hardwire it to the battery or motor.
rcstunt101 is offline
Old 05-25-2007, 03:37 PM
So either connector could connect to a spare channel on my receiver?
dorick is offline
Old 05-25-2007, 04:33 PM
Wing Chun's Avatar
Also dorick
The fan you are looking at is no where as good as the Muchmore one so when it brakes and beleive me the blades will brake. replace it with the Muchmore 30 x 30 fan
They blow hard and last 10 times longer.
Good luck
addam Smith
Wing Chun is offline
