New carpet touring car ? >
Old 03-12-2003, 09:17 PM
LeoChan's Avatar
Default New carpet touring car ?
NEW CARPET touring car use which tires best ?
& setting tip ?
Thanks !
LeoChan is offline
Old 03-13-2003, 12:36 AM
Cole Trickle's Avatar
Hmmm. It's the track that the tires should match. Carpet and carpet are two different things...
Simply use the same tire/insert combo as the fastest guys at the track.
Cole Trickle is offline
Old 03-13-2003, 01:01 AM
Sigearhead's Avatar
Trader Rating: 68 (100%+)
First you have to tell us what car you have, then you have to tell us what carpet your run on, is it ozite? Then I might be able to start helping you out with some of your questions and setup tips. Your question is too broad, give us some more details
Sigearhead is offline
Old 03-13-2003, 08:14 AM
tufferwilde's Avatar
Come on Favian.... he didn't give enough details?? Err.. nope...
Are you talking rubber tires?? If so try Sorex 20/24 with Yoke thin medium inserts
If you are talking about foams - try starting with plaids up front and purples in the rear
Wilde
tufferwilde is offline
Old 03-13-2003, 08:15 AM
peter_robinson's Avatar
Trader Rating: 21 (100%+)
go to your track nad ask the fast guys what they are running, and run those same tires.
peter
peter_robinson is offline
Old 03-13-2003, 10:27 AM
LeoChan's Avatar
Default setting & tire ?
Thanks !
I'm now only use YOKOMO & Barracuda
but not use after have race have Mr.Massami ,
i'll use MR4-TC SD this car to race
8 mins race MOD
NEW CARPET no user tester , but same asia tamiya cup carpet,
only 1 day to test my car ,
before race tamiya driver say open is no traction , race day 1
morning same no traction after more , race day 2 final morning same is no traction .
INDOOR race with air cool
use which tires SOREX 20R & 24R ?
or YOKOMO 138M2 ,138B2 & 139B2 ?
which inner ?
use how many damper oil ?
full 4WD or Oneway ?
need use anti rollbar ?
& special how to setup can fit morning no traction & PM have small traction ?
Thankyou !!
LeoChan is offline
Old 03-13-2003, 12:39 PM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: setting & tire ?
Originally posted by LeoChan
Thanks !
8 mins race MOD
which inner ?
Thankyou !!
Leo Chan'
I can give you a Good Starting point for a Barracuda for Carpet..
Tires.. I would use a Sorex 24R
Insert... HPI Red..
Oil..... Yokomo 550 rear and 600 front
Springs...HPI Gray 27mm or Pink 27mm
as for Oneways... I would use a front spool or Diff in the front..!!...dont use the the One way on Carpet with a Barracuda ....
Toe ...front 0 rear 2.1~2.5-
Camber -1 front -1 rear
also I would use a .5mm shim under the rear hex balls in the front and rear
Ride height and droop you will have to set one self.. (track buy track)
Hope this helps..
-Dave
JDM_DOHC_SiR is offline
