JR Z-1 Question: Synth. receivers... >
Old 01-14-2007, 09:17 PM
Bwadd2002's Avatar
Trader Rating: 15 (94%+)
Default JR Z-1 Question: Synth. receivers...
I recently purchased a JR Z-1 and I want to know what other receivers are compatible with this setup. The RS310 that comes stock (75mhz) is huge and takes up alot of space in the TC. Let me know your recommendations for a smaller one.....
Bwadd2002 is offline
Old 01-15-2007, 03:33 AM
CRASH's Avatar
Trader Rating: 26 (100%+)
There really is no smaller synthesized receivers out there. The JR 310 is the smallest one I have seen. Jr does make another receiver that is alot smaller but it is not synthesized. JR R330 3 channel and the R200 2 channel.
Later,
CRASH is offline
Old 01-15-2007, 08:26 AM
Bwadd2002's Avatar
Default Receivers
So thats it.... I cannot use any other receivers..?? Anybody.. do I have to switch over to KO regular setup to use the KO 302F, or do I need to switch to spektrum...
Old 01-15-2007, 08:35 AM
sharkman's Avatar
Trader Rating: 18 (100%+)
Why do you want to switch so badly. I use the 310 in my t2 007. Other then moving the antenna mount, I have plenty of room in very limited space.
I would just go spectrum with their new micro receiver instead of switching to ko.
sharkman is offline
sukh's Avatar
Clint get to work!
sukh is offline
Old 01-15-2007, 08:38 AM
Bwadd2002's Avatar
Default LOL
HEy Sukh... whats up buddy... you get to work.. LOL
See you wednesday!!
Old 01-15-2007, 08:43 AM
sukh's Avatar
I am at work.....just taking a break, and yes i will see you on wed.
sukh is offline
duckman996's Avatar
Trader Rating: 14 (100%+)
Clint - you "hack".... just switch to the Spektrum Pro and get a micro receiver.
duckman996 is offline
Old 01-15-2007, 08:47 AM
sukh's Avatar
Apparently bakker and Herbert will racing with us on wed!, Martin get to work.
sukh is offline
Old 01-15-2007, 08:49 AM
Bwadd2002's Avatar
Default All work
Why dont you all get to work!! LOL Yeah Sukh wednesday is gonn abe good racing... as long as Martin gets out of my way... 3 turn rule buddy in effect..
LOL
Old 01-15-2007, 09:35 AM
Chemical X's Avatar
I have a JR-Z1 and used the 310 synth receiver in my nitro sedan but have been been using a 27MHz KO Module and KO 302F receiver in my XRAY. I wish that JR would release an updated synth receiver that is similar in size or smaller than the KO 302F.
Chemical X is offline
Old 01-15-2007, 10:24 AM
Bwadd2002's Avatar
Default receivers
My question is... can i run a 75mhz KO 302F rec with channel 82 xtals ans still use my synth modual on the TX will that work...?
Old 01-15-2007, 12:59 PM
No, you have to use KO Propo module.
trf_racer is offline
Old 01-15-2007, 01:13 PM
theisgroup's Avatar
i think that works. we have a guy that runs the other way around. the ko module and jr rs310 receiver. and dumas also runs a ko tx module and jr 310 receivers. so I would think the other way around would work
theisgroup is offline
Old 01-16-2007, 07:41 PM
robk's Avatar
Trader Rating: 22 (100%+)
The Novak synthesized receiver works in hi response mode. The Ko receivers don't work for me, but they may work in normal mode. I did once borrow a Z1 and i used it successfully with a ko rec., but I don't know what mode the radio was in
robk is offline
