Alex Racing Barracuda R2 & R3
#1366
OK ...here is the Skinny
OK all of you guys with the Web R2 the Orange Drive System will be out at the end of this month ..July.. and also a Carbon drive shaft that is Orange also.... ...But... .. they will only be making them for a very short time and a limmited # of them to ...from what the wife asked them they are only making 50 of them and it`S a 1st come 1st serve basis ....9800 for the drive system and 2800 for the carbon shaft.....
KO..... Randman .. you had Better PM me quickly because I`m placing a order with PAL this week and I`ll need a 100% acurate web version # to get the Drive system.... I think that PAL is doing this so that one person doesn`t buy all of the Drive systems
-Dave
-Dave
#1370
GT7 on cuda
Anybody using GT7 on their cuda?? I want to change my esc to GT7 but Im afraid to get glitching problems. Some of my friends used GT7 on the EVO III and got some glitching problems because its too close to the motor or something else. When they switch to a different esc, EVO III worked fine. And when they put the GT7 on a different car it worked fine too.
#1372
Re: GT7 on cuda
-Dave
#1374
Regional Moderator
Re: Re: GT7 on cuda
Originally posted by JDM_DOHC_SiR
I use GT-7`s on my cudas with out any problems ..you`ll just need to mount the reviver on top of the servo for best reseption
-Dave
-Dave
#1379
Originally posted by Randman
Cool, is anyone running personal transponders? If so, where are they bieng mounted?
1) top of upper deck in front of the antenna
2) in a addapter that mounts the personnl one in the location next to the servo..( the addaper is made by OVA )
-Dave
#1380
R/C Tech Elite Member
I've seen the adapter in the past, just didn't want to go that route because then you are up to the size of a regular transponder. I was thinking about possibly putting it in the front foam bumper, or underneath the center shaft if I could fit it. Want to put it somewhere where the weight can be used to help performance if possible.
