Alex Racing Barracuda R2 & R3
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by RcMonk
wyd, i can email one that i had made when i get home tonite. format is a combination of the japanese alex racing setup sheet and the one on the usa website. word and pdf format.
here's a blank setup sheet in jpg.
not sure if this works with your alignment.
does anyone have an interactive setup sheet that they wish to share with us?
and i guess no one has an answer to my problem?
Tech Legend
Tech Legend
Re: shock problem!
Originally posted by raving-monkey
ok guys, ive just been setting the ride height and set 5.5 on the rear, and the all is good.
but i come round to doing the front, i set it to (well attempt to) 5.5mm but even with the shock collars all the way up, it is still 6mm+..that isn't the problem but the problem is that evening having 6mm+ ride height the shocks have no movement at all..they have about 1mm movement on left and right (only on the front)....
i hope it made sense and i was wondering if anyone else has had this problem before..if so is there a cure to it?
thanks
Matt
thanks
Matt
I did notice that the car has alot of travel. I will take a close up of the front of my car as it might help you some.
Originally posted by JDM_DOHC_SiR
OK..
hmmm how much in and out play do you have on the Axle.?? .5mm is acceptable
-Dave
OK..
-Dave
When I ran Jet Hobby front knuckles there was some play in the axles. I think the spacing between the bearings in the knuckles was not enough causing the slop. Ended up putting a 8x10x0.3mm shim prior to installing the inner 6x10 bearing. It's the same shim that I use to shim the bevel gears. Miight work in your case.
Yea I hear ya on the Jet hubs.. I had 2 that were very different..one I couldn`t even get the bearing insude the tollerance was too dng tight and the other one had mad ammounts of play..??
-Dave
-Dave
thanks for the info.
i just looked at my car and i did have longer shocks on the front..so i switched them with the rears and now the front is fine..5.5mm and plenty of shock travel.
but now the problem has gone to the rear LOL....i am thinking i got the wrong shock ends on (long ones)...am i meant to have the shorter ones on?
i probably made a simple mistake but it is hard trying to read japenese..or try and work out what the not so good pics mean
thanks
Matt
thanks
Matt
Tech Legend
You will need the short ends on the rear shocks just like the front ones.
ok, i will switch them over tomorrow when my dad brings the cuda box with the parts in (left it at my dads house )
DOH!
It's also an idea to get some short shock bodies, the same as the front ones and fit them to the rear. Otherwise you can still get a bit of limited compression at the rear. It's kind of puzzling why Alex Racing decided to bother with long shock bodies on the rear
hey, i;m a 15 yr old brit..i;ve got a decent excuse
i seen a lot of people fit yokomo shocks, or tamiya ones (they are pricey though)
is it actually worth getting different shocks to standard though?
don't want to be splashing out on things i don't need.
