Alex Racing Barracuda R2 & R3
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by protc3
hey wyd,cuda huh?i think i may have something that interests you.i will need a few weeks though.
your always a step ahead it seems
Tech Legend
Originally posted by Ko Racer
If you need some ti quick mounts let me know via a pm and I will stick them in the mail for you in the morning . I have a extra set of 4 laying in my box if you want them!
Brian
Regional Moderator
congrats on the win hermie!
youll be quite happy with the Cuda...i used to run it all last year and this past winter...i then switched to the Warpspeed TC3 and gained a second a lap ive had great results with the Cuda though at national races (1st in B at Novak and 10th in A at Triple Crown) it has tons of potential
Hi Guys,
We are back from the Reedy Touring Car Race of Champions and I want to congratulate all the guys running the barracuda this weekend, especially to Mike Rydwell (MikeR on R/C Tech) who finished 7th in the 19t A main this year. And also to Ling Kang Tong (Linger on R/C Tech) who put in a solid run in the B main. Out of 100 drivers from all over the country it is a great achievement to be in the top 10 and top 20.
I will have both of these guy's setup posted on www.alexracingusa.com in the next couple of days
Steve Wang
Steve Wang
Yep.. only a couple of more days untill you get it
-Dave
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Hi Guys,
Steve Wang
Too Bad Berger was not there this year
-Dave
Tech Legend
Ok I have my Xenon R2 taking form now. I slowly working out the bugs with the help of you guys on this thread. Thanks
Here is what I have so far.
Tech Legend
One more.
Tech Legend
Hi Guys,
Steve Wang
Hi Guys,
Steve Wang
Looks good wyd !! Are you planning on using strapping tape for the batts ? I ended up using yokomo's battery strap and posts for my Xenon R2. Whereabouts in PA are you ?
id get rid of the clear tranny boxes and purchase some aluminum bearings holders for the driveshaft....unless you wanna hear grinding with high torque motors coming out of the corners
wyd,
Car looks good! But I think you have to take off the tranny case because the chassis was designed to work without the tranny case (along with the short steering post) because the motor mount will be 1mm lower than the rest of the mounting points to the upperdeck if you're using the plastic casing and the regular height steering posts. Check it from a side view and see if the upperdeck is bending down at a small angle right now at the motor mount.
Steve Wang
Steve Wang
Steve,
I saw the R/C driver Steve bobblehead. The resemblance is so cunning that it is almost disturbing..hahahaha
multiplex
hey wyd, that red servo looks rad. and the receiver is tiny. are you using the multi radio as well?
