Alex Racing Barracuda R2 & R3 >
Like Tree5Likes
Old 02-18-2004, 11:08 AM
  #9631
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
xxxkat are you racing on carpet?
OVA is offline
Old 02-18-2004, 11:24 AM
  #9632
OVA
OVA's Avatar
Hey xxxkat my cuda did the same thing twitchy...No you don't need to change the med arm..if you are runing carpet ,the med arm are better ..first thing you want to do it reduce the streering on your radio and the front shock tower position used the third hole from outside and the rear, lay the shock all theway down to the second last holes,,and use 22 pound spring in the front and the rear 20 pound spring, this set up should smooth out your driving..works for me
NO SWAY BAR and this it rubber tire set up for high grip carpet
OVA is offline
Old 02-18-2004, 11:46 AM
  #9633
JusBox's Avatar
I have my drivetrain pretty free on the r2. With that single bearing holder that KO provided me and a lengthy break in period, i can get it to sping 8 - 10 seconds depending on how hard i flick the tires. This is with crappy steel bearings as well.
I do have a sparkly setup board now though so i get some of the r3 bling.
Also, I believe a new cuda chassis from BMI will be available soon too.
JusBox is offline
Old 02-18-2004, 11:51 AM
  #9634
BMI sponsored team chassis tester here...ill let u guys know how it goes ...this is for the R2 i assume though
R/C Anonymous is offline
Old 02-18-2004, 01:44 PM
  #9635
Oasis's Avatar
Trader Rating: 38 (100%+)
OVA,its an outdoor asphalt track, low to med bite(my cuda was HOOKED up) I just had waaaaay to much steering,I am running the white springs up front and the red springs in the back,front shocks are mounted top outside hole,bottom outside,and running a diff up front.I had my steering dialed out (75%) I guess I should dial out more.
Oasis is offline
Old 02-18-2004, 02:12 PM
  #9636
rc-zombies's Avatar
Rayspeed white and REd? I used the Red up front and white rears. The stiffer red should take away some steering and improve rear traction with the white.
rc-zombies is offline
Old 02-18-2004, 03:42 PM
  #9637
Regional Moderator
So what is BMI going to do chassis wise for the cuda? are the plans for the R2 or R3 or both
Ko Racer is offline
Old 02-18-2004, 04:07 PM
  #9638
Hebiki's Avatar
Trader Rating: 26 (100%+)
Ko Racer
spoke with MB Racer.. he drives for BMI.. i think they're making a chassis thats thicker..and moves the batteries forward. that was the last rumor i heard from him. this was back in jan at a race i saw him at. PM MB Racer.. he might know more.
Hebiki is offline
Old 02-18-2004, 05:25 PM
  #9639
Oasis's Avatar
Yes their rayspeed springs,so I should swap em,red up front and white on the rear,cool I will try that..
Oasis is offline
Old 02-18-2004, 05:32 PM
  #9640
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
Man I feel for my buddy. He ordered a new R3 and when it arrived and opened the seeal it was missing the chassis. Now he has to send it back and wait for another one to come.
wyd is offline
Old 02-18-2004, 05:51 PM
  #9641
MikeR's Avatar
Trader Rating: 15 (100%+)
I guess it will have thicker shock towers as well as more mounting holes further out... R2 right now, maybe R3 later? I'm sure they'll do all the bells and whistles like their TC3 chassis.
MikeR is offline
Old 02-18-2004, 05:52 PM
  #9642
MikeR's Avatar
Awww torture! So close yet so far!
MikeR is offline
Old 02-18-2004, 05:55 PM
  #9643
MikeR's Avatar
Try a 1mm spacer under the front pillow balls to reduce initial steering and 1mm spacer under the rearmost pillowballs to remove anti-squat. Both will help settle the car down. Are you sure the suspension isn't binding in any way also? I recommend going back to the stock springs as well- I ALWAYS end up going back to them
MikeR is offline
Old 02-18-2004, 06:14 PM
  #9644
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I need to get rid of some steering,way to twitchy for me,(R2)right now I'm running the mid arms,will it take the twitch out if I run the longer arms?
You can try longer arms, and maybe softer springs as well.
Randy Caster is offline
Old 02-18-2004, 06:17 PM
  #9645
Mike - Are you running the R3 yet, or still the Xenon car?
