Alex Racing Barracuda R2 & R3
#8372
Regional Moderator
Originally posted by Randman
Waitin for Steve to get em?
no there already selling them across the pond
#8373
STOCK R3 out of the box
#8375
nip: thanks for the short cut...save me lotsa time
#8376
Regional Moderator
So what are your thoughts on the kit?
#8377
Havent tried it yet...I expect it to be something different compare to other shaft driven...the arms are really something.
During assembly (the Jap manual...doh) have a slight guessing here and there but all in all, the alignment and fitting are perfect.
Whats your view?
Whats your view?
#8378
Regional Moderator
Whats your view?
Whats your view?
#8379
chassis is pretty solid, very minimum flex as I feel it. The rack steering is much smoother than the TC3, must be because of the delrin bushings in the middle of it.
Another thing is the motor mount block, it should give less tweak I suppose cos bottom side mounting is right down the middle.
#8380
Does R3 Have Torque Steering?
#8381
logically I think it has. How much less/more compare to say TC3, I'm not sure, haven't tried it yet. R2 owner maybe can comment on that. I can't be sure cos I don't have an R2 or even knows how much different they are.
#8382
oh ok, because Im looking into the car trying find info.. because if has Alot of torque steering going to be a pain balancing the Chassis.
#8383
GTO : Hehe, get the brushless in there quick. The acid test would be this SUnday when you pit this against Ozone's 04 and my EVO3... guess after that, you will then be able to answer everyone's question
Bring it on!
Bring it on!
#8384
I use to run TC3 on a 13sec high speed track, I can't feel the torque steer. I run my practice with Novak BL geared at 7 which i think should give me plenty of torque, I still don't feel it. It's there I suppose but I don't feel it.
#8385
