Alex Racing Barracuda R2 & R3
#7981
So they havent asked you to race at the BRCA nationals then??
Mmmmm, got any dates for races up that way, will look on the calander to see if any fall within times im up that way.
You just never know...........
Got all 3 of my Cirrus's installed and raring to go, Lot lighter than my old MRT and seem a bit more responsive too. Will be running it outdoors first weekend of the new year brrr brrrr bound to be cold and wet
#7982
If they want me to run in the BRCA nationals they can pay for the darn fuel
No set dates so far for the SMTCA, they don't normaly start until about April/June, Scottish GP is about September.
3 of them you must be a busy racer Would do more racing myself if mini pins weren't the pain in my wallet that they currently are and there was a different class of racing around here.
Outside at this time of year I know the Cirrus is water proof but is it frost proof You made a special order for some CS 12's?
#7983
Nah D20's with drawing pins pushed through from the inside out, marshalls wont go near the car though if you bin it
#7985
R/C Tech Elite Member
Originally posted by Gazza_D
Thats definately the quick way to DIY a garage
Anyway guys...have modified my Cuda with a new battery strap and it works great!!!
I think its an X-ray part but it was given to me so im not 100% sure. Works a treat for a free upgrade though
#7986
Are there any parts that need to be upgraded for the R2 to be really competitive?
Will the R3 include all these hop ups already or not?
#7987
The R2 is very competitive in stock form, any upgrade to the car is basically beefing it up for the unexpected crashes and to make it more "bullet proof". These are the "must" upgrades for stock racing: Alloy shaft holders, alloy knuckles and center oneway or speedway pal drive system with the hollow carbon shaft. For mod racing: Alloy shaft holders, Speedway Pal drive system, titanium turnbuckles, titanium screws, alloy knuckles, ceramic bearings, and a hot motor
#7988
What is the internal gear ratio of the R2? Is the R3 only the R2 but ready with hop ups, or otherwise?
#7989
#7990
Fatboy Joe, you live in quezon city? Where is there to run your R/C out there? Are there people that race em there? I was from bulacan and manila when I was growin up.
#7991
If you want to go lighter then start getting titanium bits, I'd never bother with alloy screws, too much of a risk of getting one stripped. The first titanium part I'd reccomend are the quick release shock mounts so much easier to move the upper shock position and you get a handy tool that also works on the suspension arms pillow balls. Then titanium screws because I hate philips head screws when trying to do a quick rebuild.
The kit bearings are full of thick gunk, but once cleaned out are fine. I'd only go to the big expense of high grade bearings when the kit ones start failing, which they haven't shown any signs of for me yet.
For easy to change toe in you can get the offcenter titanium nitride coated pillow balls, this gives you all the toe adjustment you could want with a quick turn of a couple of screws.
#7992
The R3 comes with pretty much the same spec as the R2, no extra hop ups.
The main change is the new motor mount/drive train and revised chassis. The new motor mount basicly incorperates a Pal Drive system or the Xenon/SpeedwayPAL chassis conversion. So alloy shaft holders are less neccesary for the car out of the box as the spur is held more securely for less wobble.
#7993
If I order some hop ups that fitted the R2, will they fit the R3 as well or better wait a bit to see the car first?
#7994
#7995
Herminator: Well said bro Although in my experience, the alloy shaft holders are a must due to chassis flex. The plastic ones are really bad, you can hear the bevel and diff gear slip during hard cornering. This not only protects the Spur gear but the drivetrains gears aswell. Whether it's an R2 or the new R3 Just my .02cents
Mclaren: Just wait till the R3 comes out. It will be worth it
I was hoping to get my R3 by the 20th of Dec but I just received an email from Xenon Racing that they are still doing some molds for the R3 and won't make it till the 20th of Dec. I guess I'll be getting mine by Jan or last week of Dec.
