Alex Racing Barracuda R2 & R3
#5402
Originally posted by Randman
I ran the inner camberlinks when I first started with the R2, but went to the outside links to get a little more aggressive feel. Never really messed with the ackerman though...
#5403
Regional Moderator
Steve ...Gald to see you back from the break and looking forward to reading your comments of the cuda and going mod with it.
#5404
shock springs?
I need to know which shock springs other than Alex racing will fit on the R2. Thanks.
#5405
Regional Moderator
Re: shock springs?
rayspeed, hpi,alex these are used the most that I know of
#5406
Re: Re: shock springs?
Originally posted by Ko Racer
there are people here that use the following brands
#5409
Yokomo's are a good size, I think HPI's are too long, giving silly ride heights.
I use Alex Racing springs now, a good range of strengths and you know they'll fit
#5410
Regional Moderator
Originally posted by rc-zombies
Rayspeed Red(front) and White(rear) works great on the car...
thats what im running and really like them
#5411
R/C Tech Elite Member
Originally posted by TC3
i tought the inner links would make the car more agresssive by increasing traction but decreasing stability .
#5412
#5413
Originally posted by SpeedTech
Herm,
Let me put it in perspective for you. At this time last year, SoCal was getting 12-15 heats on Sat. night, and this time two years ago, they were pushing 20 heats. We didn't finish racing there until 1AM at times, now I think they usually finish around 10PM
Steve Wang
Herm,
Steve Wang
#5414
#5415
Kevinm,
I'm almost done with updating the website, I do have all the springs back in stock.
The way Alex Racing spring works is they first go by wire diameter, and then number of coils. So a part number 14625 will be 1.4mm diameter wire at 6.25 coils. And they go up in increments of .25 coils. The reason for 1.5mm diameter wire is I believe to have something in between .25 coils. The difference of going from 14625 to 14650 might be too much in Alex Racing's opinion, so something in the 1.5mm diameter will fall between the 14625 and 14650.
I will have lb reading of all the shocks together soon (from Alex, to Yokomo, to associated, and Tamiya) Ling (who also drives a cuda) up north have access to an engineering grade spring dyno, and I'll have him work out all the math for us (he is a ME, he loves this stuff...I think )
Steve Wang
Steve Wang
