After market radio handwheels for big hands?????
I think Nair will work if it's still being sold.
you can also take the foam off of an old tire, lets say a newer size one but its chunked.. soak it in laquer thinner to release the glue, then cut it to proper size to wrasp the current foam.. glue it over the existing foam and you should be dialed.. i belive tm tires sells a larger foam peice for the wheels..
dawgmeat--I have looked at my friends Helios with the Gold BBS wheel from Dynamite. I compared it to the red and blue BBS wheels from Dynamite and the Gold one is a bit bigger in diameter. It is a bit larger in diameter than the stock wheel as well. Good Luck.
Brant
Brant
Brant
Brant
Originally Posted by dawgmeat
thanks pookty-tang
SHWOOOOOOOO-POWWWWW!!!!!!!!!!
Brant
Belt Tech
B-Main Motorsports
My a hands are too big for my KO Helois Radio anybody have a link to where I can buy a bigger one or a modification trick?
Check this link for more options
Also try this link for more detailed description.
Seriously though..... IMO the KO is the most compact high end radio out there. You might want to check out someones M11 or 3PK to see how they feel.
