rev 4 battery removal >
Old 12-19-2006, 08:48 AM
buffalobill989's Avatar
Trader Rating: 50 (100%+)
Default rev 4 battery removal
im looking for a shock mount for my rev4 that will mke it a quick release so its easier to remove my shock to get my batts out? a guy told me tower made one but i cant find it. anyone know of anything. i hate using jumper wires and i dont want to wear out my ball cup pulling it on and off thanks
buffalobill989 is offline
Old 12-19-2006, 08:54 AM
timmay70's Avatar
Associated ball cups are $5 for 14, and it takes me all season to wear mine out. But if you insist, you can get the shock end hardware from X-ray that a lot of people use (appearantly). You'll wind up installing a long set screw where the ball stud mounts, and the captured ball in the shock end screws down onto it...
good luck.
timmay70 is offline
Old 12-19-2006, 08:58 AM
thanks for the help. which cap ball end is it for?
Old 12-19-2006, 09:13 AM
TEM
TEM's Avatar
du-bro makes a quick release ball end. Ask the airplane guys/shops.
TEM is offline
Old 12-19-2006, 10:18 AM
Mr. Shookie's Avatar
these...
http://nexusracing.net/product_info....8cd855c31b25d7
and these....
That way you can do two cars...or sell them to your buddy.
When you install the ball onto the shock end make sure you install the ball onto the shiny side or you get binding issues.
Hope that helps,
-Shookie <><
Mr. Shookie is offline
Old 12-19-2006, 10:32 AM
burgboyz's Avatar
Trader Rating: 70 (100%+)
I like to use Sullivan RC products "removable ball link" on my twelves!
With a 'lil modification they'll last for many years.
They are sold as a package with the new ball stud.
(they are used on airplanes linkages)
http://www.sullivanproducts.com/S560n02.JPG
burgboyz is offline
Old 12-19-2006, 10:58 AM
thanks for all the help guys
