Xray T2'007
Old 03-24-2007, 12:17 AM
  #2146
adamge's Avatar
Foam-carpet racing, sometimes my chassis comes back with carpet gunk built up on the outer bottom. Is this a good sign that I'm allowing too much roll, and I should increase spring rates or raise roll centers?
adamge is offline
Old 03-24-2007, 06:16 AM
  #2147
turd ferguson's Avatar
I was told by a local pro, that it is ok as long as it is only the edges. Clean it off every run and keep and eye on it. If it starts being half the chassis, then you have to start looking somewhere else.
turd ferguson is offline
Old 03-24-2007, 07:27 AM
  #2148
The Evicerator
Oh boy...Clint's in here
Steve Weiss is offline
Old 03-24-2007, 04:30 PM
  #2149
STLNLST's Avatar
Trader Rating: 32 (100%+)
Yes I am. What are you doing in here
STLNLST is offline
Old 03-24-2007, 06:56 PM
  #2150
Trader Rating: 27 (100%+)
Originally Posted by Dane
Haha yeah - I was so excited to snap a few pictures that I didn't set it up yet.
I undersand that...Im the same way
convikt is offline
Old 03-24-2007, 08:01 PM
  #2151
Trader Rating: 16 (100%+)
The string is going to pot then...
Still Bill is offline
Old 03-26-2007, 03:08 AM
  #2152
corradopsi's Avatar
Cool
ok guys, ive got a breakage problem id like to solve. when i clip an apex too tight i break the lower part of the steering knuckle and the top of the caster block. will aluminum knuckles alone help with this. i suspect that when the bottom of the knuckle gives out, it allows it to twist in the block and break the top of the caster block too. yeah, yeah i know, stop hitting stuff, but you dont get fast driving a conservative line. this is usually a 10-15 dollar break depending on if i lose the bushings in the block or not, and id like to decrease its frequency. opinions? experience?
corradopsi is offline
Old 03-26-2007, 04:11 AM
  #2153
Aluminum steering blocks will transfer most of the damage to the c-hub. The steering block won't break but the hub will....Therefore cutting your damage control in half.
Jason
P.S.-Just got a 007 this weekend. Can't wait to run it for the last 3 weeks of racing.
Stampede is offline
Old 03-26-2007, 05:22 AM
  #2154
Get a wide stiff bumper like the one Parma has. It will help the breakage some The hobby store up here also makes their own plate out of lexan and this really helps cause you can get right out to the edge of the body. Light and durable
JoeGlover is offline
Old 03-26-2007, 06:52 AM
  #2155
Assuming that you are using the standard bumper, you need a Rubberneck bumper.
Do your axles extend out beyond the wheel nuts? They are notorious for getting snagged on the boards. Cut them down or use spacers (wider hex nuts) to make it so they don't protrude beyond the wheel nuts.
Old 03-26-2007, 07:05 AM
  #2156
Trader Rating: 55 (100%+)
hey maybe one of you smart guys could give me the list
of bearings and sizes for 007
Mo
Mo Denton is offline
Old 03-26-2007, 07:10 AM
  #2157
Mo
Did they forget your manual when they sent you the car
4x7x2.5 - 2
5x10x4 - 10
5x8x2.5 - 4
10x15x4 - 4
A. Rhodes is offline
Old 03-26-2007, 07:40 AM
  #2158
Johnny Wishbone's Avatar
Xray makes a wide front lower bumper replacement that works very good as well.
Johnny Wishbone is offline
Old 03-26-2007, 08:35 AM
  #2159
c-lyon's Avatar
Do you mean part # 301203 or a foam bumper? (If so what part # please.) I think they're referring to foam bumpers. I have the Parma, but I think the P-dub is a bit wider.
c-lyon is offline
Old 03-26-2007, 11:24 AM
  #2160
What size bearings do you need if you're running the alum. steering blocks?
Jason
Stampede is offline
