1:10 Tyre Additive >
1:10 Tyre Additive
1:10 Tyre Additive
Old 07-17-2006, 08:56 AM
gizmo360's Avatar
Default 1:10 Tyre Additive
for 1:10 Tc, Rubber, Mod, Asphalt racing :
I guess this is mostly for the Uk drivers running to BRCA regs.
could you tell me what tyre additive most of you run ! and why.
i run LRP stuff just now but would like to try something new as i feel it does not last very long into the race.
thanks.
gizmo360 is offline
Old 07-17-2006, 08:59 AM
Tire Tweak mixed with CS High Grip, 50/50. Let it sit for 30 minutes with warmers on at 45-50 degrees celcius.
Or Paragon if your track allows odor based additives.
Jan Larsen is offline
Old 07-17-2006, 09:02 AM
Tpg racer's Avatar
How about Trinity Red Dot???
Heard that they are very good tyre additive.
Tpg racer is offline
Old 07-17-2006, 09:03 AM
Trader Rating: 32 (100%+)
Red Dot is more for foam tires. Trinity Death Grip works very well on rubber tires.
A. Rhodes is offline
Old 07-17-2006, 09:08 AM
Trader Rating: 208 (100%+)
I have used red dot on rubber tire. Just let it sit for around 20-30 minutes.
Tires can get really tacky.
dodgeguy is offline
Old 07-17-2006, 09:09 AM
gizmo360's Avatar
some others have said tyre tweak also ! is it made by trinity ?
and can you use on own or does it HAVE to be mixed ?
the lrp stuff is nice and easy to put on !
gizmo360 is offline
gizmo360's Avatar
gizmo360 is offline
Old 07-17-2006, 09:12 AM
Trinity Tyre Tweak is also very good on rubber tires, but might be harder to find that Death Grip.
DIP is another very good traction compund for rubber. I beelive it is dist. by Schumacher.
Old 07-17-2006, 09:18 AM
gizmo360's Avatar
is the dip called Hybrid DIP ?
what about ( trinity Death Grip Traction (Rubber RC4063 )
gizmo360 is offline
Old 07-17-2006, 09:40 AM
Not sure on the exact name for DIP.
Yes, that is the correct part # for the Death Grip. They also sell it in a package with Death Grip and Cleaner, don't know the part # off the top of my head though.
Old 07-17-2006, 09:58 AM
John_S's Avatar
i think schumacher usa distribute dip products but uk dont
John_S is offline
Old 07-17-2006, 10:06 AM
housey's Avatar
yeh CML distribute hybrid stuff in the uk, which includes the DIP additive.
housey is offline
Old 07-17-2006, 02:23 PM
Drcy's Avatar
Default Tires
Hi all,
I am having one important race in a big track with medium to low grip .
Air Temperature will be 21°C or 81°F.
Since any rubber tire/insert/rim combination is allowed and no limit for the number of tires used - is a total new situation for me , used to run TakeOff C27 limited to 2 sets per race (mandatory tire).
I will be thankfull for any advice base on experience about how to get the best of this conditions, like which tire/insert can be the best
and
If is wise to use one tire set for each run (4 qualifying and 3 finals).
By the way,
If is hot (above 27°C use Black Label LRP or TQ
if is between 23° and 27° air temp. use CS High Grip
if is bellow 23° use Jack the ripper blue color
thanks in advance
Pedro
Drcy is offline
Old 07-17-2006, 11:46 PM
gizmo360's Avatar
what kind of additive do the top guys tend to use ?
like masami , moore, hara , spashett , etc etc
does anyone know ?!
gizmo360 is offline
Old 07-18-2006, 08:36 AM
hpipro321's Avatar
paragon ground fx
hpipro321 is offline
