Mamba Max....
#301
I've attached a Tamiya Brushless Motor to my Mamba Max and the only way to get it was by trial and error. Attach the wires, check to make sure the motor is spinning in the correct direction, if not, change one pair and do it again.
It says in the Mamba Max manual that the connections have no polarity, so there should be no problems with this.
A perhaps simple question?
I am trying on a different motor for my Mamba max and the markings on the motor does not match the mamba esc markings...
I need to know which motor cable to put where?
Mamba ESC is albeled R,W and B on the motorcables and the motor is marked A,B and C
So where does R W and B connect on the motor
