monster pro+XXXS GP+socal = gearing?
#16
Re: Monster Stock
Originally posted by popsracer
Guys;
Try the RED spring on BOTH sides. On my Dyno it was good for over a 1 watt increase in power.
I haven't experimented with brushes yet so there may be more to gain. I'm also going to re-check the armature balance as I think it is off. Should be able to reduce the spool-up time with a correctly balanced armature.
Guys;
so whats the down side of this setup? if there isnt any, trinity would have been doing that for a long time! im quite sure trinity only hires motor expert to build their motors so experimenting with brushes is nonsense, its just a waste of time. trinity has more advance machines that experiments these stuffs. so all u gotta do is.... buy a 4499 brushes, get the red and green spring combo like what the manual says. easy as that. if u see any different results on ur experiment, it either has a downside or it simply a waste of time becoz as i said, trinity would have been doing that for a long time if it really works. they have more knowledge, period.
#17
Well, we tried to help and that's all we can do. It's up to you to do whatever you choose with our advice. To each his own.
"Watcha eating tonight? low-main again?"
"What it 'B' like?"
Like I said, I'll buy your motor for 10bucks if you think its useless. Or you can listen to our advice and just do it. Would we lead you astray?
"What it 'B' like?"
#18
"What it 'B' like?"
"What it 'B' like?"
ur 10 bucks is only worth two pinions. two pinions is all i need to set a perfect ratio for socal.
#19
I'm glad you didn't take me up on the $10 dollar offer. Just stick with the monster and find that magic gearing. Also use 4499's (or the newer brushes, don't have the #) and try trinity black springs on both sides (i think black is the same tension as red) but it works for me.
#20
hey maybe we can meet at socal? im the guy with the orange alpha with a big NOVAK sticker on the hood. do u know brian? most of the time i sit next to him.
