Novak US Touring Car Championships @ S&N's Trackside Hobbies >
Old 01-09-2003, 09:46 PM
  #31
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
Great info...man Josh can wrench...Go Randy Cook and the Oklahoma Boys....
Jeff Werner is offline
Old 01-10-2003, 01:17 AM
  #32
johnbull's Avatar
Hi guys. Greetings from Malta.
TSR6. You really had me foxed with that first chassis picture you showed.
At first I thought Josh Cyrul was running his TC3 with a carbon chassis.
Then I saw the TRF stand it was sitting on!!!!!!!
Can't blame me can you. It's even got the cells down the wrong side, like the TC3.
Keep up the good work. I'm following it all through RC Tech as usual, so keep the info coming.
Thanks again.
Joe from sunny Malta.
johnbull is offline
Old 01-10-2003, 07:00 AM
  #33
BigDogRacing's Avatar
Great job Troy- keep up the good work!!!! I know what a pain it is to upload that stuff.
If you're using Photoshop, remember that batch processing is by far the easiest fastest way to compress all your pics at once.
Please PM me if there's anything I can do to help.
BigDogRacing is offline
Old 01-10-2003, 07:11 AM
  #34
RCTech Member #2
TSR6's Avatar
Sorry, That is David Jun's Chassis that was asked for in the thread in the Racing forum.
BigDog - Thanks! It's hard to go from a cable connection at home, to a 56k at the track. It took over five minutes just to send a zip file of images to Futureal.
..and thanks for the Photoshop tip. I have been re-sizing every image like a dummy, I forgot all about that. :P
I also forgot to add, the guys who looked fast that i mentioned earlier, Josh, Paul, Brian, These are the guys who were tops on the printout I was looking at. Unfortunately not all the drivers had a personal transponder, So I'm sure there are a couple guys who are in the "top" lap times, but did not show up on the list.
S&N Trackside is doing an awesome job at posting lap times for each practice round for the guys who are running the personal transponders.
Now only if i can remove my on-power push!
TSR6 is offline
Old 01-10-2003, 10:17 AM
  #35
trackdesigner71's Avatar
Troy- you guys gonna be able to post video?
trackdesigner71 is offline
Old 01-10-2003, 03:31 PM
  #36
whats the latest boys?
Old 01-10-2003, 06:37 PM
  #37
RCTech Member #2
TSR6's Avatar
I'll have todays heats results a little later tonight. Heats are not done yet..
Hopeful on the video. Gotta run,
-Troy
TSR6 is offline
Old 01-10-2003, 07:43 PM
  #38
Trader Rating: 90 (100%+)
Anybody know how Chris Doseck is doing????
RBLove is offline
Old 01-10-2003, 07:50 PM
  #39
Reduce front droop a little or less rear toe.... maybe reduce front ride height .5 or raise the rear .5mm. - Just a few ideas in case you overlooked something.
Good luck Troy- thanks again for the updates!!!
Old 01-10-2003, 09:12 PM
  #40
RCTech Member #2
TSR6's Avatar
bigdog - thanks. I worked on the car a little after my run... might help a bit.. Im getting to the track early to make a couple practice runs before heats start up again.
I honestly don't want to go overboard on the changes, as the car is consistant (driver is another story )
Tonight's heat Results attached below:
File Type: txt
TSR6 is offline
Old 01-10-2003, 09:42 PM
  #41
RCTech Member #2
TSR6's Avatar
The latest milled chassis from Brian Kinwald:
Attached Thumbnails Novak US Touring Car Championships @ S&N's Trackside Hobbies-bkchassis.jpg
TSR6 is offline
Old 01-10-2003, 11:03 PM
  #42
over gear's Avatar
Trader Rating: 18 (100%+)
TSR6: could you list what car the top10 mod drivers drive?
over gear is offline
Old 01-11-2003, 08:00 AM
  #43
TRL
Default tc3 set-ups
tsr6
I was just wondering if you could get a set-up from baker,blackstocks cars?Just curious if they are running one-ways or spools and any other info you could steal would be great
Thanks!
TRL is offline
Old 01-11-2003, 03:10 PM
  #44
RCTech Member #2
TSR6's Avatar
Round Two results:
Sportsman Top 5
1 BOB MARTINEZ 17/4:11.03 | >17/4:01.28
2 DAN GIACALONE 16/4:00.58 | >17/4:04.43
3 SARAH ERNST 16/4:06.25 | >17/4:09.12
4 DEREK ENGLAND >17/4:10.46 | 17/4:17.05
5 JIM SCOTT 16/4:01.72 | >17/4:13.11
Mini Top 5
1 KEN PEPE 18/5:06.58 | >19/5:11.97
2 MARK BORGWARDT 18/5:06.42 | >18/5:06.25
3 DAN BUTCHER 18/5:11.30 | >18/5:06.84
4 DAVID WEIR >18/5:10.38 | --- DNS ---
5 KENNY DIBB -- DNS --- | >18/5:13.41
Stock Sedan Top 5
1 JUSTIN ZORC 22/5:05.98 | >23/5:05.38
2 DARRIN LEIST 23/5:12.07 | >23/5:07.02
3 JOHN ERMER >23/5:08.20 | 23/5:11.39
4 MATT DELGIUDICE >23/5:08.61 | 22/5:07.22
5 ANDREW MILLER 23/5:11.51 | >23/5:09.73
Modified Sedan
1 JOSH CYRL 26/5:03.85 | >26/5:02.82
2 BARRY BAKER 26/5:07.18 | >26/5:03.68
3 PAUL LEMIEUX 26/5:10.60 | >26/5:03.72
4 DAVID JUN 26/5:09.15 | >26/5:05.89
5 DAVE VERA >26/5:07.59 | 26/5:10.86
Expert Stock Top 5
1 MIKE DIBB 24/5:06.02 | >24/5:05.34
2 BRIAN LUTZ >24/5:07.11 | 24/5:09.92
3 TIMMY HEISER >24/5:07.40 | 23/5:08.11
4 BRAD JOHNSON >24/5:08.22 | 22/5:07.26
5 JASON MAYER 23/5:02.17 | >24/5:08.66
Factory Stock
1 JOSH CYRUL 25/5:07.27 | >25/5:06.27
2 PAUL LEMIEUX 24/5:02.77 | >25/5:08.05
3 RALPH BURCH JR 24/5:01.98 | >25/5:11.70
4 BRIAN JUCHA 24/5:01.86 | >25/5:12.18
5 ANDREW CARTWRIGHT 24/5:03.95 | >24/5:00.57
Full results:
File Type: txt
TSR6 is offline
Old 01-11-2003, 03:36 PM
  #45
Steevo's Avatar
Hi,
Could someone please tell me what cars the top 5 drivers in Mod class are running.
Steevo
Steevo is offline
