novak GTX help
did you try emailing Novak's tech support ??
did you follow this?
With GTX connected to (at least) a receiver & a charged battery pack:
1. TURN ON THE TRANSMITTER’S POWER
2. PRESS & HOLD GTX’S ONE-TOUCH/SET BUTTON
3. TURN ON THE SPEED CONTROL’S POWER
With transmitter throttle at neutral, and still pressing the SET button,
slide the GTX’s ON/OFF switch to ON position.
4. CONTINUE HOLDING SET BUTTON UNTIL RED LED COMES ON
5. RELEASE GTX’S SET BUTTON AS SOON AS LED TURNS RED
6. PULL TRANSMITTER THROTTLE TO FULL-ON POSITION
Hold it there until the green status LED turns solid green.
Note: Motor will not run during programming even if connected.
7. PUSH TRANSMITTER THROTTLE TO FULL-BRAKES
Hold it there until the green status LED blinks green.
8. RETURN TRANSMITTER THROTTLE TO NEUTRAL
Red status LED will turn solid red, indicating that throttle is at neutral,
and proper programming has been completed--you’re done.
NOTE: If transmitter setting are changed, programming must be repeated. If
you experience any problems, turn off ESC and repeat programming.
step 6–one-touch programming
You should try emailing Novak and I'm very sure that Charlie will give you full assistance...Best customer service ever...
You try rebinding the spektrum stuff before setting up the speedo?
Also, did you make sure you have the servo and ESC plugged into the right sockets on the RX? It could actually be going into setup mode, but with no change in throttle input, the red LED will just stay solid. Steering, channel 1, Throttle, channel 2..
Tony
Tony
