Old 05-27-2006, 07:19 PM   #1
Got Xray?'s Avatar
Send a message via MSN to Got Xray?
Default need help with t2 gearing etc.
hey guys i just got my t2 and have not even run it yet.
I need to know the pinion i need to use.
I have an 84 tooth spur (48p) and am using a 19t and sometimes a 27t stock.
I have all pinions from 21-30 except 29.
I need to know which pinion to use.
!xray!
Got Xray? is offline   Reply With Quote
Old 05-27-2006, 07:37 PM   #2
Send a message via AIM to Mongo Send a message via Yahoo to Mongo
Round ones.....
Way to many variables to just throw a number out there. each track is different. Ask people for there roll out at your local track then dial yourself in, or find someone with an Xray.
Mongo is offline   Reply With Quote
Old 05-27-2006, 07:56 PM   #3
Got Xray?'s Avatar
Default heres my track
Im sure someone can help me......the only xrays at my track are evo2's so no help there.
Maybe a look at out track will help: www.jdk.com.au/racemodels.html
!xray!
Old 05-27-2006, 10:14 PM   #4
xray racer's Avatar
Trader Rating: 22 (100%+)
JDK
I ran a 21 tooth pinion with the stock 84 tooth spur in stock last time i raced, on a flowing track with high top speed- so try there... you will probably use between 19-23 at your track... only judging by photos as it seems to warrant fairly high top speed right???
try it and see... start from 20 and work up, you should find the right one in there
Hope that helps
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 05-27-2006, 10:16 PM   #5
xray racer's Avatar
That was with foam tyres though so if you race rubber you may want to gear down a tooth or two
Cheers
Robbie
Robbie Lloyd
Old 05-27-2006, 10:20 PM   #6
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
try an fdr of 5.4
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 05-27-2006, 10:39 PM   #7
Got Xray?'s Avatar
Default what
What is the internal ratio of the t2? is it 1.7???
!xray!
Old 05-27-2006, 10:40 PM   #8
xray racer's Avatar
yes, its 1.7
Robbie Lloyd
Old 05-27-2006, 10:49 PM   #9
Got Xray?'s Avatar
Default so......
so if i wanted to get a fdr of 5.4 i should go with about a 27t pinion with 84t spur?
!xray!
Old 05-27-2006, 10:53 PM   #10
Got Xray?'s Avatar
Originally Posted by xray racer
JDK
Hope that helps
Robbie
There is 2 high speed sections,coming down the straight on both sides.
But we have 3 different track setups and on 2 of them,coming to the end of the straight you come into a sweeping corner.
so its half high sped the other half is technical qnd requires you to be quick.
!xray!
Old 05-28-2006, 09:28 AM   #11
buzz06's Avatar
Send a message via MSN to buzz06
you want a 26 pinion with that mate
84/26 = 3.2307692
3.2307692 X 1.7 = 5.4
buzz06 is offline   Reply With Quote
Old 05-28-2006, 04:08 PM   #12
Got Xray?'s Avatar
84/26 = 3.2307692
Thanks for all the help every one...i am going to use a 26t and just fine tune from there.
!xray!
Old 05-28-2006, 11:29 PM   #13
Also chk here .. www.gearchart.com That way you can print out a chart with all your gearing needs .....
Mark Barden .
mb racer is offline   Reply With Quote
Old 06-15-2006, 11:16 PM   #14
Got Xray?'s Avatar
FDR of 5.4
I will be using a 18t pinion with my 84t spur and stock 27,is this good?
!xray!
Old 06-16-2006, 12:14 AM   #15
WRXTC's Avatar
To work out your ratio's you divide the Spur gear by the pinion ie: 84 divided by 26 which = 3.203 then you mulitply that by your internal ratio which is 1.7 which = 5.49230. Should be fine for that track.
If you use a 19t pinion your ratio will be 7.515
WRXTC is offline   Reply With Quote
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
